586,080 active members*
3,692 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > PM25MV CNC Mach 3 Spindle control question
Results 1 to 13 of 13
    Jan 2007
    12
    I was curious if anyone has converted a PM25 CNC using mach 3 for spindle control. I am curious if there is a wire diagram, or pictures, video or explanation anywhere as to how it should be wired.
    Unfortunately there is no jumper pins on the board like the G0704, so I will have to cut the pot wires and use those.
    Dave
    Jan 2007
    12
    Re: PM25MV CNC Mach 3 Spindle control question
    Anyone?
    Aug 2006
    671
    It should be fairly easy to map out the current wires with a multimeter. I haven't cracked mine open to look, but I assume its a standard 3 wire pot inside. I say chop the sucker. worst that happens is you have to splice them back together.
    Jan 2007
    12
    Quote Originally Posted by CS900 View Post
    Opened things up last night and turned motor on, tested the pot output at full speed (5v). Spliced into the 3 wires that are going to the pot, got my BOB configured and I am having an issue. The spindle turns on/off, and my 0-10v port is tuned for 5.0v at 2500 RPM. I have set up my spindle pullies but when I change the RPM in mach, the motor rpm does not change (although the voltage output does).
    Messed with it for a bit, and then wired the POT back in but the pot does not control the speed either - it is all (full speed) or nothing (motor doesn't spin at all). When the pot is below full, the motor turns off completely.
    Any ideas?
    Aug 2006
    671
    how are you controlling the 0-10V signal with mach3? spindle break out board?
    Jan 2007
    12
    I have a C11GS breakout board. I have my isolated 12V supply going into the inputs of the breakout board, the ground from the POT wired to the ground of the 12V power supply, and my "wiper" wire going to the 0-10V output of the C11GS BOB.
    Jan 2007
    12
    Spent some more time on it last night and I have it working well now. Speed up, speed down, m03 and m04 commands work as expected.
    Aug 2006
    671
    awesome. what was the problem?
    Sep 2016
    4
    yz400fer69,
    That's great that you got it working. Any chance you can post a wiring diagram? I'd like to do the same with my PM25.
    Skip
    Jun 2013
    14
    I have a new PM25mv and was gearing up to control the spindle speed from my BOB. Didn't seem to work, so got in there with a voltmeter to try to understand what's up.
    I don't know if I believe the readings, but it seems that the pot is adjusting an AC voltage from the controller board. That could explain the very odd results I'm getting.
    There's no way my (or any) BOB will put out AC voltage to control a spindle motor.
    Anyone out there getting similar readings? In the meanwhile I've implemented a simple relay control (in the F-OFF-R circuit). Pretty easy, at least I get spindle on/off. I can dial in the speed by hand.
    Sure do wish they'd publish a schematic...
    Neil
    Jan 2007
    12
    Hi Neil,
    I was able to get my machine 100% controllable with Mach3 and a C11GS BOB. I purchased a separate / dedicated 12V power supply to control the 0-10 (spindle speed).
    I used 2 of the 3 relays to control the M3/m4.
    Send me a few pictures of what you have to [email protected] and let see if we can figure it out.
    Dave
    Quote Originally Posted by nar View Post
    Neil
    Jun 2013
    14
    Hi Dave and thanks for the reply. The BOB I have does indeed have a separate 12v supply, and provides a 0-10v dc output controlled by spindle speed S commands. I have confirmed that this aspect does indeed work.
    Here is a small excerpt from the "schematic" that PM provides:
    Attachment 364898
    I experimentally determined which side of the Speed pot was the negative terminal (ground, or so I thought), cut the line to the wiper (middle terminal) and then connected my 0-10v BOB output between the ground lead and the newly isolated line that previously went to the wiper. I expected the motor speed to follow the DC voltage coming from the BOB. It didn't.
    I then re-connected the original pot and measured the voltage between the wiper and the ground terminal and got some VERY strange readings. In DC-reading mode my meter was distinctly not happy, the readings jumped around like crazy. I then switched to reading AC voltage, and then the readings were stable if a bit puzzling, ranging from about 5vAC to 8vAC as I turned the knob.
    I'm not yet convinced that my connections were good, I will go back and repeat the above with fresh wiring. In the meanwhile, I'd really like to know what worked for you. Also, what is the vintage of your PM25, perhaps we have different controllers?
    Even if I could make this work, I'm leery of controlling speed with a BOB that does not support Charge Pump safety (are you using this feature?).
    Neil
    Mar 2018
    Has anyone figure out how to control the spindle direction and speed? I'm planning to work on this next couple of days and I'll appriciate any pointers.
  1. question to owners of pm25mv / tm25v with brushless/beltdrive
    By Redeeman in forum Benchtop Machines
    Last Post: 02-05-2016, 07:26 PM
  2. ESS to C32 spindle control with Mach 3.
    By ballistic42 in forum Benchtop Machines
    Last Post: 08-09-2015, 02:39 AM
  3. PM25MV or Grizzly G0704? New speed control on PM25?
    By Bearhawk LSA in forum Benchtop Machines
    Last Post: 12-17-2013, 01:23 PM
  4. SX3 Spindle Control via Mach-3
    By JimsCNCZone in forum X3/SX3/G0619/G0463
    Last Post: 09-05-2012, 11:00 PM
  5. Mach 2 / 3 VFD Spindle control
    By JpBinc in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-18-2008, 04:46 AM
