586,117 active members*
3,378 visitors online*
IndustryArena Forum > Hobby Projects > Gunsmithing > AR-15 A-3 flat top upper forging model
Results 1 to 6 of 6
    Mar 2010
    13
    Has anyone come across a 3d cad model for the AR-15 A3 upper forging. I have a detailed print but not to familiar with how to create some of the features in solidworks, was kind of hoping someone out there already did the leg work and doesn't mind sharing.
    Mar 2007
    29
    Re: AR-15 A-3 flat top upper forging model
    I've got the .igs file if you want it.
    -WRM
    Sep 2013
    147
    Cncguns
    Mar 2010
    13
    WRM,
    Thank you but I found what I needed.
    Mar 2010
    13
    thanks for the info Newman but that is the complete upper. I need the forging model
    Jul 2014
    8
    Somewhat related, but how would you machine the 90 degree wall for the slot where the BCG's gas key fits into the receiver. The rear takedown pin lug would prevent an end mill for going in perpendicular. I'm guessing use a shaper or broach.
  1. looking for an AR-15 A3 upper forging model
    By nrankin in forum Solidworks
    Last Post: 11-25-2016, 03:33 AM
  2. FLAT PATTERN LAYOUT FROM A 3D MODEL
    By ross33912 in forum Mechanical Calculations/Engineering Design
    Last Post: 06-01-2014, 08:44 PM
  3. ar-15 upper reciever
    By cncsdr in forum MetalWork Discussion
    Last Post: 01-24-2010, 02:25 PM
  4. HOW? Flat pattern from model or spline
    By Shotout in forum Mastercam
    Last Post: 01-19-2010, 07:59 PM
  5. Floating upper nozzle
    By Klox in forum Waterjet General Topics
    Last Post: 05-10-2003, 12:49 PM
