I'm wondering if I have a problem with my z-axis.
1) When I use the CNCRP touch plate to zero a bit, I notice that when I say "goto zero", it is still visibly higher than the material which it should pretty much be touching.
( as an aside, I am still getting an inconsistent back off distance when zeroing. Somethings it retracts to 38.5 mm, other times 63.5. Can't see a pattern.
2) This week I surfaced a fretboard with it held in a vacuum jig. After I epoxied in the inlays, I put it back in the jig and told it to surface again. This should have got me inlays (and epoxy) totally flush with the rest of the fretboard, but I found they were still being left high. I then modified the program for negative "stock to leave" in 2 thousands of an inch increments. I had to all the way to -.006" before I actually removed all the high points.
Also in prep of 2, I also tried setting z-zero by just dropping the bit onto the surface and then tightening, but still no good. I suppose 2 could be due the FB getting sucked down a little lower in the vacuum jig this time (although it seemed to bottom out), but what about 1?
I am calibrated using the settings file that came from CNCRP.
Thoughts?
