586,106 active members*
3,049 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > is it ok to mount a leadscrew to a bearing without machining?
    Jan 2016
    33
    I was wondering if it was ok to mount leadscrew inside of bearings without machining the ends.
    also to prevent back and forth motion of leadscrew... do you ususally do this with shasft collars?
    thanks for the help!
    Re: is it ok to mount a leadscrew to a bearing without machining?
    Whether it's OK or not depends on who you ask.
    But plenty of people have done it, and yes, they use shaft collars.
  1. Newbie leadscrew support/bearing question
    By lukaslouw in forum DIY CNC Router Table Machines
    Last Post: 09-17-2016, 04:13 AM
  2. Bearing mount and Housing
    By bmurph in forum RFQ (Request for Quote)
    Last Post: 05-03-2015, 11:35 PM
  3. How would you mount this bearing block?
    By HereinCS in forum DIY CNC Router Table Machines
    Last Post: 08-18-2010, 10:23 PM
  4. help for mount bearing ballscrew
    By p_rabid in forum Linear and Rotary Motion
    Last Post: 05-16-2009, 09:11 AM
  5. Bearing mount
    By vger in forum Mechanical Calculations/Engineering Design
    Last Post: 02-08-2008, 08:56 AM
