586,036 active members*
3,737 visitors online*
IndustryArena Forum > Maintenance in General > Maintenance DIY Discussion > Air pump for oil mist coolant (for DIY CNC router)
    Sep 2015
    10
    Question Air pump for oil mist coolant (for DIY CNC router)
    Hi, folks,
    I have just finished my CNC router, and now come to the conclusion that for milling aluminium (especially soft 1050) oil mist system is a must.
    In EU there are a lot of online shops that sell very cheap Chinese HAILEA piston oil-less compressors.
    For example ACO-318, 60 L/min, 0.02 MPa.
    There are others, more powerful models from the same manufacturer if necessary.
    http://www.hailea.com/e-hailea/product3/ACO-318.htm
    I'm going to use it with receiver and automatic on/off pressure sensor.
    Is his pump suitable for oil mist system, or I must look for something else?
    Thanks in advance for any suggestion(s) !
    Sep 2016
    50
    Quote Originally Posted by LinuxGuru View Post
    Hi, folks,
    I've also looked at that air pump, but the bigger version with 70l/m ACO 328 and trying to figure out if it's enough airflow/pressure to clear the chips,
    I'm mostly after the chip clearing, and some lubrication and cooling just for tool life,
    I consider to buy one just for testing purposes,
    Have you bought one? And got any real life experiences with the pump?
    Sep 2016
    353
    Hi, folks,
    Hello
    I was wondering if you had any luck with this? I currently use a silent compressor which is actually noisy inside a flat. Also it is around 1kw and generates lot of heat too. It would be great to switch to above pump if possible.
    Cheers
    S
    Jun 2010
    4256
    Re: Air pump for oil mist coolant (for DIY CNC router)
    Dunno. What pressure and what air flow?
    Cheers
    Roger
  1. Replies: 8
    Last Post: 08-09-2016, 04:55 AM
  2. Is Kool Mist eating my coolant pump?
    By icepick method in forum Benchtop Machines
    Last Post: 01-27-2015, 11:49 PM
  3. How much air for mist coolant?
    By Memran in forum Benchtop Machines
    Last Post: 02-08-2012, 10:15 PM
  4. Boss 5 Mist pump plumbing question
    By rogerfries in forum Bridgeport / Hardinge Mills
    Last Post: 07-26-2010, 05:13 AM
