586,437 active members*
3,851 visitors online*
    Sep 2016
    5
    Interact series 1 with TNC145...
    Hi all, new here - and just purchased our first CNC - a Bridgeport Interact series 1 with TNC145 control...
    I haven't picked it up yet, but would like some info from anyone with experience of them. I understand the controller will not allow 3 axis movement, is this correct? If so, can planes be selected to allow contouring at 0 degrees?
    I intend to machine rudimentary surfaces using Mastercam, but if it struggles can I fit a more advanced controller?
    Thanks in advance.
    Chris.
    Sep 2016
    5
    Re: Interact series 1 with TNC145...
    Not much help with that one, so will have to learn by doing I guess.
    One problem I am encountering though is the rs232 cable link - Is there an adaptor plug available that I could use with a standard USB connector? It's looking like I may have to purchase a laptop with a 25 pin rs232 port unless I can find something that will work.
    Has anyone on here found something they can recommend? Thanks in advance...
    Chris.
    Feb 2009
    Hi there, I have a series 1 Bridgeport with a 145tnc , I use rs232 cable and got a cheap adaptor from eBay to use it with a use . It works fine like that using the hiedenhain software to transfer it. Some where I have the cable configureration from what I remember 2 pins have to brige together .
    Adam
    Sep 2016
    5
    Hi Adam, thanks for responding.
    I have ordered a usb/rs232 cable and have found this. Does the configuration look familiar?
    Cheers,
    ChrisClick image for larger version.
    Feb 2009
    Hi Chris,
    i've just tried looking for the email i had with the settings but i cant find it but im sure i have it printed out some where, i'm sure the board is wrong i think it should be 2400.
    i will keep looking to see if i can find the print out.
  1. Bridgeport Interact Series 1, TNC145
    By jack-pat in forum Bridgeport / Hardinge Mills
    Last Post: 02-16-2015, 01:17 PM
  2. Bridgeport interact with Heidenhain TNC145
    By johnn1 in forum Bridgeport / Hardinge Mills
    Last Post: 02-14-2012, 10:05 PM
  3. Interact 1 ser 1 TNC145
    By paulvidgen in forum Bridgeport / Hardinge Mills
    Last Post: 06-15-2011, 08:19 AM
  4. Interact / TNC145 buttons not working
    By Mike Woo in forum Bridgeport / Hardinge Mills
    Last Post: 04-29-2009, 01:29 PM
  5. interact tnc145
    By bigbaz in forum Bridgeport / Hardinge Mills
    Last Post: 02-02-2008, 05:19 PM
