586,075 active members*
3,749 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Need Help About steppers in new machine build
    Feb 2007
    191
    Hello everyone
    Iam bulilding a new machine,Cutting Size 4 x 4 foot.
    Materials is Mostly in square tubbing scheddule 2.5mm, 50 x 50 mm and 25 x 50mm
    Gantry's weight is near 100 pounds includind wires and router
    V wheels over 19 mm angle rails
    I will use 2 steppers in Y axis
    Screws will be 1/2 x 10TPI 5 Starts with antibackslash nuts
    Materials to cut will be, soft plastic, acrilic plastic, and soft wood.
    Do you think that I can use this machine with
    420 in/oz bipolar steppers and a 36 volts Kelling drivers?
    Sorry my bad english
    Thanks for your help
    Kind Regards
    Rene
    Dec 2014
    640
    Re: Need Help About steppers in new machine build
    Pay attention to the inductance of the steppers. I didn't do that when I purchased mine. My 270oz motors had a little over 5mH inductance and really needed 70v to run them to full potential. I'm only pushing 48v into them with no problem so far. Since you're using two motors to power your Y, you might not need that much torque on those two motors....just a thought.
    Feb 2007
    191
    Thanks fretman
  1. New build - seeking advice on electronics/steppers
    By richthorn in forum Stepper Motors / Drives
    Last Post: 03-06-2014, 01:54 AM
  2. Replies: 3
    Last Post: 01-05-2013, 05:24 AM
  3. Just bought plans to build my new CNC - Now for steppers?
    By p-cad in forum DIY CNC Router Table Machines
    Last Post: 10-20-2011, 10:43 PM
  4. 4x8 router build, 387oz steppers enough?
    By jbluetooth in forum DIY CNC Router Table Machines
    Last Post: 03-14-2009, 11:15 PM
  5. First build - 8020 with servos or steppers
    By sandiegocadcam in forum DIY CNC Router Table Machines
    Last Post: 03-24-2008, 11:21 PM
