586,036 active members*
3,846 visitors online*
IndustryArena Forum > MetalWorking Machines > Toyoda > X axis off from center of pallet rotation
    Aug 2016
    So I run a toyoda vf 60, and am boring a part 180 degrees apart on the B axis. My bores are coming out .002" offset. so if I put a .001" in the common offset they come out perfect. I am wondering if there is a parameter I can change to offset where machine X zero is to solve the problem for future machining?
    Aug 2016
    Re: X axis off from center of pallet rotation
    Oh and I am using the side of a tombstone and using Machine coordinates to machine my part. so one side would be X-15.2171 and the other X15.2171, thanks.
    Aug 2016
    If anyone has any answers as to how I can solve this problem I would be greatly appreciative!
  1. Replies: 5
    Last Post: 07-26-2019, 09:21 AM
  2. HS-1 RP pallet rotation
    By GITRDUN in forum Haas Mills
    Last Post: 08-25-2014, 01:38 PM
  3. Pallet Rotation on a PFH-4800?
    By Race 10 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-19-2013, 06:13 PM
  4. KITAMURA 630i rotation of pallet
    By CLEVELAND23 in forum Kitamura
    Last Post: 03-20-2013, 08:58 PM
  5. datum center of pallet?
    By RCD ROG in forum FeatureCAM CAD/CAM
    Last Post: 12-17-2012, 05:58 PM
