586,471 active members*
3,826 visitors online*
IndustryArena Forum > MetalWorking Machines > Deckel, Maho, Aciera, Abene Mills > Gildemeister CTX400 Serie 2 - Spindle cannot turn!
Results 1 to 7 of 7
    Sep 2016
    Post Gildemeister CTX400 Serie 2 - Spindle cannot turn!
    Hi everyone, I discovered this forum just recently, and will really appreciate it if anyone has a similar experience with this case I am having and is willing to give some tips.
    Our company owns a CTX400 Serie 2 CNC lathe machine by DMG, and its main spindle does not turn anymore!
    Here is what I did:
    1. I initialized the CNC (Closed the safety door, turned the drive on, clamped the chuck, initialized the feed to reference point, specified tool number)
    2. I set the main spindle speed to its minimum (50 rpm)
    3. I commanded the spindle to turn either CW or CCW (both does not turn)
    4. The whole drive stopped, and error message appeared, saying "No phase current in S1 axis motor lines" Then, the message told me to check "the DC link voltage, motor feed lines, and fused in the power module."
    I merely checked the three power wires going to the main spindle with the clamp ammeter, and it showed that each wire carried a constant and same amount of current upon activation.
    Sometimes the spindle would slightly twitch after command, but that's it.
    Does anyone have any idea about how to fix this? Thank you!
    Jul 2015
    12
    Re: Gildemeister CTX400 Serie 2 - Spindle cannot turn!
    Quote Originally Posted by Richard5635 View Post
    Here is what I did:
    probably you have problem with you spindle amplifier.
    How do you clamp the chuck? I have Gildemeister CTX 520 linear and I can't to clamp chuck. If I clamp it, than I can't unclamp. How to adjust the analog sensor and pressure switch?
    Best regards
    Dec 2010
    Hello,
    The same situation is here (gildemeister nef320)
    Have you got any solution for this problem?
    Thanks, Pctvsat
    Dear both,
    a typical indication of a defective spindle drive.
    Feel free to contact me on [email protected] for a offer on a new/exchange unit.
    BR.
    Freddie O. Gaardbye
    Apr 2017
    10
    Gildemaester ct60 fehler 430
    Hello,
    I have the same problem with gildemaester ct 60 machine
    When I want to start the machine the spindle is briefly started and then it stops to report the error to the fehler 430. Does anyone know what the problem is?
    Best regards
    Quote Originally Posted by OSA View Post
    Hello,
    Best regards
    Hello,
    I have same problem. What the solution of?
    Best regards
    Hi all,
    we just replaced the LT-module and it fixed the problem.
  1. Gildemeister CTX400 Eltro Pilot Keypad
    By flynno83 in forum Controller & Computer Solutions
    Last Post: 01-03-2021, 05:41 PM
  2. index g200 vs gildemeister mf twin 65 vs emco turn 465
    By pedro pinto in forum Uncategorised MetalWorking Machines
    Last Post: 10-14-2015, 01:44 AM
  3. Gildemeister CTX400 with heidenhain pilot
    By robkavitch in forum Post Processors for MC
    Last Post: 10-26-2013, 03:04 PM
  4. Any Gildemeister lathe operators out there? I'm looking for opinions on 5 axis CTX400
    By MadMax in forum Uncategorised MetalWorking Machines
    Last Post: 03-08-2013, 07:36 PM
  5. interact 4 spindle drive won't turn on spindle
    By 0041601 in forum Bridgeport / Hardinge Mills
    Last Post: 06-23-2008, 11:51 PM
