Originally Posted by
Jorge-D-Fuentes
I went and loaded the SHADOW TEST.dxf that you attached.
I don't see any 3D polylines that would cause a problem (everything looks 2D and, as you pointed out, all z coordinates are set to 0)
As for your question regarding if it will 'confuse the LASER'...
I'm not sure about your LASER cutter, but on my LASER engraver, any lines that are in 3D space cause a problem ONLY if you are attempting to hatch-blast the area within their perimeter. However, when using the lines as a toolpath for an outline, the LASER just ignores the Z coordinate and essentially is 'projecting' the linework on to 2D flat space.
I imagine your LASER would behave similarly. But you're right; the only way to know is to try it out.
