Hello all,
I am new to mastercam and I tried to machine a marble part using mastercam
And stl file.
The tool center which is not cutting, hit the marble and broke it.
I think the problem is that I used tool in mastercam as End mill, but clearly it is not.
But I don’t know what tool I must choose from mastercam tool manager which is similar to the one I have.
The tool I have has 5 mm cutting length 85 mm diameter.
Toolpath area roughing, 3 mm cut, 1.5 mm (add cuts)
What solution I have to continue this part?
Which tool I must choose which corresponds to the one I have?
Are any settings in toolpath that will help?
Please see pictures.
Thank you
