586,115 active members*
3,523 visitors online*
    Sep 2016
    Post CNC communication
    Im a newbie here but here's my question. I have a laptop that I use a DNC program to communicate with our Mits FX10. Been working great. I just added a Haas VF3 machine and decided to order new communication cables with USB adapters. I cant get this to communicate. I've set the com ports correctly (I believe) and still not communicating with the EDM (haven't tried VMC yet). Now in th midst of this my operator tells me he broke a pin in the 9 pin port so I cant use the 9 pin connector anymore. I have a new laptop coming but really want to be able to communicate via USB . The DNC software that I use is IWorkshop CNC file transfer. Anyone use this DNC program? Any help would be appreciated.
    Jul 2016
    30
    Re: CNC communication
    Sounds like you need to troubleshoot every single part of this system. Does the USB adapter work? Can you push/pull through it using another application like HyperTerminal? Once you prove it works you need to get your application working with it. Contact the DNC software support department.
  1. No communication?
    By rookie191 in forum Fadal
    Last Post: 07-07-2015, 08:16 PM
  2. ip/tcp vs. com communication
    By Rylee in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-07-2011, 08:11 PM
  3. Communication
    By neilthib in forum Fadal
    Last Post: 12-13-2010, 09:27 PM
  4. PC<->NC communication
    By loky in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-27-2007, 09:44 AM
