586,635 active members*
3,005 visitors online*
Results 1 to 13 of 13
    Jun 2016
    16
    Mach 3 WITH ESS C62 BOB AND DYN4
    I have the Estop to work on mach3 cant get DYN4 SERVO TO WORK
    I install a jumper wire on the C62 ESTOP PORT
    24 VOLT TO POWER THE C62 BOB AND THE ESS
    I AM NOT SURE FOR THE CONFIGURATION JUMPER TERMINALS ON THE C62 BOB
    I AM NOT SURE FOR THE PORTS AND PIN IN MACH3
    ANY HELP WOULD BE APPRECIATES
    THANKS
    Oct 2016
    28
    Re: Mach 3 WITH ESS C62 BOB AND DYN4
    any luck figuring this out? im in the same boat with a C62, uccnc 300 Ethernet , and dyna 4 drives and motors...documentation almost non existent.
    Jun 2016
    16
    it working with the help of cnc4pc
    what is your problem ?
    mach3 or mach4
    i could send you some picture of my set up
    Oct 2016
    28
    im trying to set up uccnc
    Jun 2016
    16
    send me your e mail it wont let me load the pic on the forum
    Jun 2016
    16
    Attachment 337416
    - - - Updated - - -
    - - - Updated - - -
    - - - Updated - - -
    - - - Updated - - -
    Attachment 337424
    Jun 2016
    16
    - - - Updated - - -
    - - - Updated - - -
    Jun 2016
    16
    - - - Updated - - -
    Apr 2008
    204
    you should only have 5v to the c62 and ess.
    Oct 2016
    28
    thanks for your replies and pictures. cnc4pc sending me a few things to get me going.... im also using uccnc so my operation system is different.
    Oct 2016
    28
    are you happy with your set up? any issues?
    Jun 2016
    16
    VERY HAPPY WITH THE SET UP
    Oct 2016
    28
    What part of Canada you from? I'm 15 minutes from Cornwall, Ontario.
  1. Anyone with experience from DYN4 drives and LinuxCNC?
    By nschmidt in forum Dmm Technology
    Last Post: 05-29-2019, 06:14 PM
  2. DYN4 enclosure wiring help
    By usmarine21m in forum Dmm Technology
    Last Post: 08-29-2016, 04:30 AM
  3. DYN4 wiring
    By dynoluc in forum Dmm Technology
    Last Post: 06-05-2016, 03:11 PM
  4. Dyn4 and Arduino rs232 communication
    By JPMach in forum Dmm Technology
    Last Post: 08-20-2015, 06:40 PM
  5. DMM DYN4 Enable signal.
    By rob2290 in forum Dmm Technology
    Last Post: 06-02-2015, 01:18 AM
