586,313 active members*
3,295 visitors online*
    Jan 2015
    26
    Question Slow rapids with Mach 3
    Hi guys,
    I'm using Mach3 and Sheetcam and my rapids are way slower than when I move manually with arrow + shift. Since my arrow- shift speed is fine I guess my motor tuning is ok and it must be a setting somewhere else?
    Any suggestions?
    Thanx
    Lama
    May 2014
    5
    Re: Slow rapids with Mach 3
    Quote Originally Posted by Lama2 View Post
    Hi guys,
    Any suggestions?
    Thanx
    Lama
    Did you sort this out ? Having same problem
    Thanks Brett
    May 2014
    5
    Got it sorted. It was Windows, and the only thing not to work running 64bit. Re installed usung the 32 bit disc and its got
    G00 rapids
    Apr 2017
    9
    Quote Originally Posted by Tasibrett View Post
    G00 rapids
    I have the same problem: G0 rapids are much slower than e.g. jogging (even when set lower than 100%)
    Can anyone tell me if 64bit Windows is really the problem here?
  1. Slow down rapid G00 in Mach 3?
    By rideredcr in forum Taig Mills / Lathes
    Last Post: 09-25-2012, 02:04 PM
  2. X2 CNC with IM804 drivers, lots of resonance and slow rapids
    By The Aspirator in forum Benchtop Machines
    Last Post: 10-22-2011, 02:30 AM
  3. need help rapids going very slow
    By mls in forum Hardinge Lathes
    Last Post: 05-07-2010, 04:34 PM
  4. Mach 3 slow tracing
    By Mr.Chips in forum Machines running Mach Software
    Last Post: 01-14-2007, 04:05 AM
  5. Cut speed is stuck at Slow????Mach 2
    By mwalach in forum Mach Mill
    Last Post: 08-24-2006, 12:58 PM
