586,055 active members*
4,176 visitors online*
Results 1 to 6 of 6
    May 2012
    8
    Kvara NC on Beam Saw - 'Magic' brand.
    Hi!
    Had a Magic M90 Beam Saw being recommissioned when it stopped working.
    'PLC in Blocco' is the error, and an SCM tech in UK told me the PLC file is corrupt.
    Has anyone out there got, or know of, a 'Magic M90 (or M65)' Beam Saw.
    I got passwords from ESA in Italy, who make the Kvara, but only the 'initsys' works on this unit, so I presume different ones are needed.
    I cannot access the 'H' or 'I' drive, and the 'F' drive now says 'File not Found'
    Can anyone tell me how to get this unit set up?
    I copied files off it, including KVARA.GZ, which is big (800k).
    Any help greatly appreciated, especially copies of files for a Magic unit.
    Service SCM BR Guest
    Re: Kvara NC on Beam Saw - 'Magic' brand.
    Hello,
    To solve the problem PLC IN BLOCCO is necessary to perform the AutoSetup. From step 1 with the formatting and reset the CN ESA loading the PLC in step 12.
    But the important thing is to know why the PLC has been Blocked.
    Usually the reason is the 3.7volts lithium battery is low on charge. CNCs old KVARA5 or 6, Or battery CR202 for NEW ESA S500.
    Is it must be replaced with the machine.
    For Autosetup occur without errors is necessary to folder C: / KVARA with the correct files for the Serial Number of your machine.
    Enviado do meu iPhone usando Tapatalk
    May 2012
    8
    Many thanks!
    The battery seems OK, 3.67V, but I have replaced it anyway.
    Where can I get the setup instructions and files?
    I have copied any files I could find on the unit, which is Kvara 4, code KVR.0004.COS04, Serial No. 20012049.
    Did SCM take over the 'Magic' brand, do you know?
    Best regards,
    Tim.
    Hello Friend.
    You did very well to replace the battery.
    For detailed information I believe you need to contact the manufacturer CN. The ESA.
    But in CN we use in SCM, (and I know not taken the Magic and not part of SCM Group). within the C: \ Kvara there is AutoSetup.ini file and
    within the folder C: \ Kavara \ Exe you run the basemenu.exe
    File that it had opened in auto setup mode where you choose the Language and then starts the auto setup procedure step 1-12.
    Is it ok?
    Aug 2017
    4
    sorry but i have the analog problem but i do the autosetup but when it arrive at plc loading there is a message "file non found: /c:slowplc.cmd its urgently sorry for english i'm italian
  1. C-Axi HSD Brand Aggregate *BRAND NEW*
    By mlepisto2 in forum For Sale Only
    Last Post: 09-24-2014, 07:41 PM
  2. Meldas Magic 64 Pc Control fitted to L&W Magic Boy 1000
    By Flash_Gordon in forum Mitsubishi controls
    Last Post: 10-21-2013, 01:52 PM
  3. The magic of mud!
    By cncadmin in forum EnRoute
    Last Post: 10-12-2011, 07:40 AM
  4. How align IR beam (co2) with visible beam (red dot laser) ?
    By etienne delcuve in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-04-2009, 12:41 PM
  5. Short beam/Long beam? - Basic design
    By Pat2000 in forum Mechanical Calculations/Engineering Design
    Last Post: 11-10-2005, 05:49 AM
