Hi all
I have bought a CNC from China, the issues are many, but I'm in a position now where I have fixed most of them.
The problem I need to solve now is configuration without any instructions.
My system
6090 CNC
2.2KW water cooled Spindle
MACH3 USB Controller - Xulifeng USB
86BYG250 4A Stepper motors (NEMA 34's ?) (SOYA Branc
DMA860H Stepper controllers
FULING DZB280B002.2L2DK Inverter
I've fixed a lot, replaced most of the power cabling, to Aust standards,
I have managed to get the unit basically functioning, but not configured I'm hoping someone can share their Mach3 configs if they have similar configs.
The areas I believe I'm lacking knowledge/info is:
Setting the limits
Configuration of the pins & ports
Motor tuning and setup (XYZ & spindle)
I've gone through some movement calibration, but not there yet.
setting the motor home soft limits (where do I get this info from ?)
Setup input signals
Setup output signals
The manufacturer does not respond, no instructions or specifications sent other than what I have determined from testing and looking up the specs.
Any directions or guidance appreciated
