586,110 active members*
3,392 visitors online*
    Feb 2016
    New CNC with no config info
    Hi all
    I have bought a CNC from China, the issues are many, but I'm in a position now where I have fixed most of them.
    The problem I need to solve now is configuration without any instructions.
    My system
    6090 CNC
    2.2KW water cooled Spindle
    MACH3 USB Controller - Xulifeng USB
    86BYG250 4A Stepper motors (NEMA 34's ?) (SOYA Branc
    DMA860H Stepper controllers
    FULING DZB280B002.2L2DK Inverter
    I've fixed a lot, replaced most of the power cabling, to Aust standards,
    I have managed to get the unit basically functioning, but not configured I'm hoping someone can share their Mach3 configs if they have similar configs.
    The areas I believe I'm lacking knowledge/info is:
    Setting the limits
    Configuration of the pins & ports
    Motor tuning and setup (XYZ & spindle)
    I've gone through some movement calibration, but not there yet.
    setting the motor home soft limits (where do I get this info from ?)
    Setup input signals
    Setup output signals
    The manufacturer does not respond, no instructions or specifications sent other than what I have determined from testing and looking up the specs.
    Any directions or guidance appreciated
    Apr 2014
    432
    Re: New CNC with no config info
    There is a Mach set up pdf .I sought of went one Item at a time then looked it up there are a lot of conflicting views out there. wade through it and and you come out the end with a better understanding .You may have someone close to you but Aus is a big place .
    Jun 2010
    4256
    The vendor may not be the mfr. Often is not, just a trading house. They have zero knowledge.
    Your best bet would be to look for someone who can come on-site. 5 minutes on-site can equal several days by web.
    Cheers
    Roger
    Dec 2014
    103
    You tube can help alot when learning this stuff
  1. Looking for Info, Patent #'s, Info on Milling Machine Automatic Tool Changers
    By CNC-Joe in forum Uncategorised MetalWorking Machines
    Last Post: 08-22-2013, 05:41 PM
  2. Need help with config
    By justin bowser in forum Mach Mill
    Last Post: 05-09-2011, 01:53 PM
  3. Replies: 7
    Last Post: 02-04-2011, 03:21 PM
  4. How do you backup your config.
    By CATCH22 in forum Mach Mill
    Last Post: 12-21-2007, 04:13 AM
