586,106 active members*
3,238 visitors online*
Thread: Miyano cnc
    Jan 2007
    Miyano cnc
    Hi.
    I recently moved our Miyano and now It wont run. Ipress start and no hyd. come on but I get an alarm 401 servo.
    I press reset but it just clicks in the panel and the alarm comes up again.
    any ideas please.
    Gasher
    24221
    It helps if you give the the controller, If your hydraulics are not on then you don't have any power probabally to the servo's either, check the term 5&6 of the servo board if 110v missing, then you have a e-stop power problem more than likely.
    You need to get the schematics out and do some logical trouble shooting.
    Al.
    Albert E.
    Jan 2007
    Al the Man
    Thanks for your reply.
    The control is 6 T
    Hope this means something to you.
    Gasher
    Try changing the phasing of the power to the machine
    Swap any two wires.
  1. RS-232 Setup for Miyano w/Fanuc OT
    By JerryH in forum Fanuc
    Last Post: 01-20-2012, 02:17 PM
  2. is a miyano mtp-3 non existant ?
    By dt38k in forum CNC Tooling
    Last Post: 12-21-2006, 03:29 AM
  3. RS-232 Connection Miyano w Fanuc OT
    By JerryH in forum DNC Problems and Solutions
    Last Post: 12-28-2005, 03:13 AM
  4. Miyano Live-Tool
    By JerryH in forum G-Code Programing
    Last Post: 10-26-2005, 01:50 PM
  5. Miyano BND-34S Programming Help
    Last Post: 10-10-2005, 02:11 AM
