586,058 active members*
3,768 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > G540 and NPN Prox. Switch
Page 3 of 3 123
Results 41 to 53 of 53
  1. #41
    Mar 2007
    2083
    Re: G540 and NPN Prox. Switch
    Hi Nicolas
    just looked at the video and its a capacitive sensor with an operating range of 1 to 25 mm
    the n/c hall proximity switch that came with my tachometer module switches when the magnet is about 10 mm away
    I expect your switches will be very similar but when you take for the gantry to stop as you say the gap has closed to 3mm or 1/8"
    how about turning the proximity switch by 90 degrees so the magnet passes by end of the switch
    John
  2. #42
    May 2009
    1332
    Yes I could turn the switch 90 deg. but then it will be sticking to the side of the machine and prone to damage (that’s where the enclosures you suggested earlier comes handy).
    I thought it was possible to add some electronics and make it adjustable. I remember I was reading about these prox switches and I saw something about adjustable but when I ordered them I forgot about the adjustable feature.
    No problem, I will manage somehow but now I think the micro limit switches with the lever are much better and easier to install
    Nicolas
  3. #43
    Mar 2007
    2083
    Hi Nicolas
    just found this-
    LJ12A3-4-Z/BX DC 6-36V 200mA 3 Wire NPN NO 4mm Inductive Proximity Sensore Pulsante
    it gives the detection distance of your switches as 4mm !!
    how about putting the magnet on a spring mount and adjusting the switch position more to the right as seen in your photo - so the axis should stop sooner
    now if the gantry does not stop in time , the magnet can be pushed back against the spring when the switch and magnet make contact
    John
  4. #44
    May 2009
    1332
    When you say “putting the magnet on a spring mount” which magnet are you referring John?
    Nicolas
  5. #45
    Mar 2007
    2083
    Hi Nicolas
    existing magnet that operates the proximity switch
    I can't make out from the photo how its mounted I guess its glued to the reverse side of the vertical part in the photo
    John
  6. #46
    May 2009
    1332
    Sorry John but as you know this is the first time I get involved with prox. switches
    I have no magnet installed on my machine, I thought you are refering to the blue part at the front of the switch itself
    Nicolas
  7. #47
    Mar 2007
    2083
    Hi Nicolas
    Sorry for the confusion
    at 1:30 this morning I confused my self and forgot your proximity switches are inductive the type and not Hall switches like I have with the tachometer module that needs a magnet !!
    if arranging the proximity switch for a metal flag to pass over the end of the switch
    then a spring loaded plunger ( without the magnet !) could still be used to protect the switch from the occasional over travel
    the data sheet I found -
    Attachment 341894
    does not indicate if its more sensitive to some metals than others
    it may be worth testing it with pieces of steel , aluminium and brass
    John
  8. #48
    May 2009
    1332
    No problem at all John
    I found an alternate way for the installation which will not damage the sensor if I have an overtravel and I will send you a picture when I’m done.
    However I foreseen a problem with the Z axis due to the limited space available.
    On the G540 is it possible to combine NPN sensors with micro switches (the ones with the lever)? These micro switches have 3 terminals (NO, NC, COM) and if it’s possible how do I wire them to the G540?
    Nicolas
  9. #49
    Mar 2007
    2083
    Hi Nocolas
    you can wire the microswitch across the blue and black wire that the proximity sensors are connected to
Name:	G540 +  proximity switches +microswitch + star point ground.jpg
    John
  10. #50
    May 2009
    1332
    That's very good news John, thanks
    Nicolas
  11. #51
    May 2009
    1332
    Hello John
    I tried a setup as per post #32, method #1 but still the sensor must be a few millimetres away from my gantry to be activated which is too close for comfort. Looks like I will not use these prox. switches and that I will go back to micro switches. Luckily I have enough micro switches to finish my job
    But for future projects are all NPN (NO) proximity switches similar? Perhaps there are other types which you have an adjustment on them to increase the sensing distance?
    Nicolas
  12. #52
    Hi Nicholas
    im wondering did your method work by connecting
    X + / X- / X Home / Z + / Z- to Pin 1
    Y + / Y- / Y Home to Pin 2
    A Home to Pin 3
    Probe to Pin 4
    I am currently building a CNC machine using Gecko G540 drive and stuck with the Wiring Proxymity switch problem ...
    I hope you can help me ..
    Thank you very much
    Regards ...
    Cakra Beddu
  13. #53
    May 2009
    1332
    Sorry mate, I never used those prox switches as I found the distance to trigger the switch was very small, don’t remember but I think it was a few millimeters, and so I went to what I used before, the lever type. Simple and effective
    Nicolas
Page 3 of 3 123
  1. solid state prox switch question
    By xkadet in forum CNC Machine Related Electronics
    Last Post: 03-07-2013, 12:30 AM
  2. Need help understanding switch G540
    By skylanehku in forum Gecko Drives
    Last Post: 09-24-2012, 05:33 PM
  3. Prox switch/DC polarity circuit question
    By Skiroy in forum CNC Machine Related Electronics
    Last Post: 08-08-2011, 05:19 PM
  4. Really dumb Prox switch question
    By dfmiller in forum DIY CNC Router Table Machines
    Last Post: 05-12-2011, 08:58 PM
  5. Relay with G540 and a manual switch? 2nd try
    By Fastest1 in forum Gecko Drives
    Last Post: 02-27-2010, 11:22 PM
