With the appropriate metal cutting blade (same material that your grinder and cutoff wheels are made of) from your home improvement center, you can cut steel with a circular saw. You just may not want to. It is a real PITA. The carbide blades are much better than those, although they may be designed to spin slower.
I use a number of 4.5 inch cutoff wheels and grinding wheels spinning at 10000 + RPM on metal all the time. You know how messy those are, the one for the circular saw is even worse.
Best solution? borrow a torch and get ready to be grinding for a while.
"If the women don't find you handsome, they should at least find you handy"
-RedGreen show.
