Well I can offer some opinions and some of my experiances.
The steppers seem large enough for the job at hand, however you'll never run those steppers through the Nexen Rack's and keep the pinion's from blowing up [check the torque spec's]. I also doubt that they are more accurate than Ballscrews. I guess depending on the grade of ballscrew they might be but.. don't matter as they'll just bust on ya if you use them. Note also that this is assuming your using some type of reduction as direct drive would be too course of a resolution [distance per step] to be of use. For a table that size Ballscrews are the order of the day. Check out some websites like Nook or Misuimi [spelling] and see what they recommend for sizes to counter the whip issues that are going to crop up. You'll need to figure out what reduction you'll use as well as the needed power [at stepper rpm] to cut at the speed you want. Then know what lead to use to get that speed, then you can figure out screw RPM and figure out what size will not whip. I'd think a 1.5 to 2" ballscrew is going to be needed [if not larger].
I think that you could do it in 400 lb's but that would be lite. I'd shoot for more like 1000. If you really want to cut Alum/steel, if its just wood you'd be fine at 4-500.
I'm building a fairly large mill and I'm over a couple thousand already. I'm using rack and pinion for the X and Y axis, but then they are 20 and 10 ft respectivly.
As Zumba said, get it designed as its a complex pc of equipment and you'll having nothing but headaches if you don't know how its going to go together before you start. Either that, or it will look like it has warts all over it from just 'hanging' things wherever they 'look about right'.
Ger21 has pointed out that larger rapids and feeds will make it a real workhorse, also he mentioned that it will take a pretty good spindle, at these speeds I don't think a 3hp plunge router is up to the task, do you have a spindle picked out? I would first decide on what I want to spend, then find a spindle in the range and design towards that, that way you won't have a machine w/ a 2 hp spindle that could [ in theory] at 400ipm, but effectivly can only cut at 100 because of the spindle. 7-10hp is probably going to be required, that is unless you only want a DOC of 1/16" then the 2-3 hp would probably do it!
Keep at it! It's a terribly addicting past time, as well as expensive but I think it has its rewards for sure.. nothing like building something on a machine you've created and built. [ I've not felt that feeling yet, but in the next few weeks I hope to! ]
Jerry
JerryFlyGuy
The more I know... the more I realize I don't
