586,409 active members*
3,261 visitors online*
Thread: RS232 Help
Results 1 to 10 of 10
    Feb 2007
    5
    RS232 Help
    I'm A new at the zone but have read alot of posts here.I am having trouble
    sending programs to my Fanuc 3t. I can recieve back to my computer but can not send. Please help!!!!
    Jerry
    2932
    Do you get alarms? Which ones? Are you trying to send the same program back?
    Feb 2007
    5
    No alarms, just sits and flashes LSK. I have tried different programs, different setting, cables. Could the board be bad if you can send with no problems?
    Thanx,
    Jerry
    2932
    1. What communications program are you using to send/receive? Are you set up for hardware or software handshaking? It could be your software is waiting for a DC code from the control.
    2. How is your cable wired?
    3. Have you tried hooking up a RS-232 Tester to the cable and/or the machine?
    4. Do you have other machines in your shop communicating with the same PC? If so, try the same cable on other machines.
    Mar 2006
    13
    In the program you are trying to send, is the first character a "%" ? Try that.
    Mar 2005
    1498
    070311-1557 EST USA
    Jerrytool:
    Have you ever solved your problem?
    Feb 2007
    5
    No I have not solved it yet. I still am in the same position, I can send to PC no problem but can not recieve. Any suggestion would be great.
    Thanx,
    Jerry
    Mar 2005
    1498
    070312-0958 EST USA
    Jerrytool:
    What does the beginning and end of a program look like?
    For example:
    O0030
    (a first comment maybe)
    (is there a : instead of the letter O in the program name)
    then program stuff
    M30
    Your dump from the CNC to the computer should tell you if this is the required structure.
    If this is the structure, then create a program like this:
    O0100
    (X)
    M30
    This is 13 characters plus carriage returns and line feeds. Try sending at 1200 baud. See if this will load. It might be small enough to avoid any buffer problems.
    What if any error messages occur with this?
    Mar 2004
    761
    Check your TVON parameter setting.
    http://www.cnczone.com/forums/archiv...p/t-18783.html
    Wayne Hill
    Mar 2007
    17
    Check The Program Protect Key , Make Sure It Is Set To Write Enable.ran Into This The Other Day On My 21-tb,some Joker Flipped The Write Protect Key ON And I Could Send Programs But Not Recieve.took Me An Hour Of Checking Computer,settings And Parameters.looked Down And Noticed It Was Changed To Write Protect.
    Don't Know If This Is Problem But It Sure Gave Me Fits!!!!!
    TOOLMAKER
  1. Meldas 64 ASM and rs232
    By KombianCNC in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-20-2007, 11:31 PM
  2. USB to RS232?
    By Klox in forum Computers / Desktops / Networking
    Last Post: 11-29-2006, 09:11 PM
  3. Problems you have or had with RS232?
    By gar in forum Polls
    Last Post: 12-22-2005, 05:21 PM
  4. RS232 & other things
    By alwayslearning in forum Uncategorised MetalWorking Machines
    Last Post: 07-26-2005, 01:12 AM
  5. Mach2/3 and RS232
    By jderou in forum Mach Software (ArtSoft software)
    Last Post: 05-28-2005, 01:10 PM
