Originally Posted by
SCzEngrgGroup
Most common failure is a blocked metering valve. Those little brass fittings screwed into the manifold that the oil lines attach to contain a check valve, and a metering orifice, to meter the oil flow, and allow it to be balanced between the circuits. The orifices are VERY easy to clog, and once clogged nearly always need to be replaced. After having failures on all my previous machines. I re-plumbed my current machine to have NO valves. I ran a separate line from each oiling point to a 14-way selector valve, so I can pump pressurized oil to each circuit individually.
Regards,
Ray L.
