586,032 active members*
2,993 visitors online*
    Dec 2006
    310
    Alarm 7 on PSM and 11 on SPM
    Dear Sirs
    We have a turning center with Fanuc 0T and alpha drive
    Yesterday Alarm 7 on PSM and 11 on SPM appeared only when spindle stops (as per program) in auto cycle and axis moves up.
    Today none of the machines running, this machine also showing no errors, we are observing DC voltage to be 320V (range 280 to 325VDC), no error in auto cycle without component or load
    Do u suspect improper braking inside SPM causing overvoltage while running on load
    Will it help if we replace SPM as incoming voltage is OK ie 206V phase to phase, there is no stabliser to this machine
    Pl advice
    Rishi
    Quote Originally Posted by M.RISHIKESH View Post
    Dear Sirs
    Pl advice
    Rishi
    What was the solution to the issues? We had the same alarms yesterday when the spindle was stopped as programmed and manually using M5 command.
    Dec 2015
    171
    Re: Alarm 7 on PSM and 11 on SPM
    Problem in alpha PSM module you have go & repair it.
    Quote Originally Posted by phucrobusl View Post
    Thanks! We’ll start there!
  1. Replies: 27
    Last Post: 02-09-2022, 05:10 PM
  2. Replies: 4
    Last Post: 05-03-2019, 08:58 PM
  3. Mazak QT 15 Alarm 14 Drive alarm z axis
    By Rodent73 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-12-2013, 01:21 PM
  4. Replies: 6
    Last Post: 03-13-2013, 03:32 PM
  5. Replies: 4
    Last Post: 06-12-2009, 09:15 PM
