586,058 active members*
3,252 visitors online*
    Mar 2016
    10
    problem with cutmaster 52
    Hello everyone,
    Ive been having on and off problems with my cutmaster 42 so on friday the esab rep gave me a new cutmaster 52 to use for the weekend. Its being used on a cnc table so i set it up and burned two sheets of 3/16". Perfect. On the third sheet it started fine but about 5min into cutting it stopped piercing. i changed out all the consumables (tip, electrode, shielding cap and even the start cartridge)...still having the same issue. its acting like there is no ground attached and just gouging the material. no settings have changed and its the same material. Before i call the rep and voice my concerns with the unit i thought some of you guys may have an idea for me to try. Thanks in advance!
    Jun 2008
    562
    Re: problem with cutmaster 52
    Make sure the torch plug is seated all the way in. Had a issue with mine where I did not have it properly seated and could not get full power to the torch. It may feel seated, but make sure the collar is .03-.06 from shoulder.
    Is your pierce height in spec. I lowered mine by .025.
    Mike
  1. CNC Cutmaster A80 Arc Issue
    By ryanthegreat1 in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 03-11-2014, 02:18 AM
  2. TD Cutmaster 51
    By rock4xfab in forum Waterjet General Topics
    Last Post: 01-11-2012, 04:03 PM
  3. cutmaster 152
    By Cable Guy in forum Waterjet General Topics
    Last Post: 08-18-2009, 01:34 AM
  4. looking for cutmaster 102
    By metalcut in forum Waterjet General Topics
    Last Post: 08-02-2008, 02:43 AM
  5. Anyone using a Cutmaster 80XL ???
    By pnwcustoms in forum Waterjet General Topics
    Last Post: 01-09-2007, 05:32 AM
