586,060 active members*
4,339 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal Idler problem. Rpm pulse problem
    Oct 2016
    I have a Fadal 2216 that recently started to have an RPM surge up and down problem, mostly a lower RPM. The load meter goes up and down with the rpm of Spindle. if I keep spindle over ride at just below 100% it will stop surging. I just found a big air leak in the lower cylinder when that idler is not in use and extended. if I set RPM to use the higher RPM settings the lower cylinder does engage and air leak mostly goes away. Does anyone know if I change the lower air cylinder with the air leak coming out around shaft, if that will fix my problem.
    Jim
    Jan 2015
    417
    Re: Fadal Idler problem. Rpm pulse problem
    Well at Fadal they had a saying Fix the obvious first so i would replace the cylinder.
    ITS: High Low Idler Cylinder, CYL-0006
  1. Pulse-coder, motor, or Velocity Control Problem
    By bergen13 in forum Cincinnati CNC
    Last Post: 11-13-2013, 05:21 AM
  2. Stepper Motor Pulse Input Problem
    By scratali in forum Stepper Motors / Drives
    Last Post: 05-20-2012, 09:07 PM
  3. uploading to fadal problem
    By bobo17 in forum Fadal
    Last Post: 03-14-2010, 01:10 AM
  4. fadal problem
    By Delvis in forum Uncategorised MetalWorking Machines
    Last Post: 02-09-2010, 05:09 PM
  5. pulse train to vfd, deceleration problem
    By chimpera in forum Mach Software (ArtSoft software)
    Last Post: 11-09-2009, 07:55 AM
