Dear friends , Hi .
I use kitamura mycenter 1 , with fanuc 10M controller.
My problem is that: the feed rate (G1) is reduced in the arcs and circular toolpaths . it reduced too much (became about 10 mm/min) although its value in the program is for example 500 mm/min .Also the movement of the tool in these areas becomes non contineous .
In these case the machining time incresed too much .
I have also used G2 and G3 codes , It became a little better but I think the movement of the tool could be much smoother . :tired:
I had the same problem for heidenhain controller , I have used M90 in front of each program block and the movement became much smoother and the feed rate does not decreased in arcs and circular toolpaths :banana: . but the M90 does not work for fanuc 10M .
It will be your kindness if you help me :drowning: because in these case the machining time is too much and it is not possible to work in this condition. :drowning:
You can also mail me your answers . my e-mail address is [email protected]
Thank you in advance
Alan Minasian
