586,069 active members*
3,599 visitors online*
Page 1 of 2 12
Results 1 to 20 of 25
    Oct 2016
    23
    Is there a hobby waterjet like a Wazer?
    Does the DIY hobby world have a kit for making something like the Wazer? It seems a quality pressure washer and a replacement mixing nozzle from a professional waterjet could do great things.
    Wazer link
    May 2014
    170
    Re: Is there a hobby waterjet like a Wazer?
    On some soft stuff it would. You can chip concrete with a 6000psi washer. But no, it's not like the one they made. I am pretty sure they made an actual intensifier pump. Could be wrong
    Sep 2016
    Cutting would take a fair amount of pressure however... in my experience anything below 900 bar is rather useless.. Understand slow and average quality of cut..
    Jul 2007
    27
    WARDJet offers several size build it yourself "kits" of an industrial waterjet cutter that cuts at 60k psi
    https://wardjet.com/products/waterjets/wardkit
    They had students and others putting one together at the IMTS show.
    Jun 2005
    1730
    $80K, yeah that sounds like hobby level. LOL
    Neat had no idea anyone even made a kit.
    Oct 2016
    23
    I guess not. That's kinda surprising. I know 6K psi would cut slower than 60K psi, but it would work. Heck, the Grand Canyon was cut with almost 0 PSI. I have a feeling Wazer runs on a standard pressure washer given the limited background of the creators.
    If it did, then someone would be doing it.
    Wrong.
    Oct 2016
    23
    Wrong.
    You stopped in to call my wrong. Care to elaborate?
    Feb 2009
    6028
    Our waterjets don't cut worth a darn under 20k psi. I sure as hell wouldn't want one at my house. Dirty messy high maintenance and high consumable things.
    Sent from my A3-A20FHD using Tapatalk
    Oct 2016
    23
    Boo-ya baby! Cutting 1/16" aluminum with a $150 pressure washer at 2" per minute.
    https://www.youtube.com/watch?v=Lg__B6Ca3jc
    Jun 2005
    1730
    CutOnce,
    Very interesting experiment. Actually your setup worked pretty well and for hobby CNC this would probably be pretty effective. I will have to check out Wazer as well, but using a WJ to cut aluminum would be pretty nice.
    Russ
    Jun 2007
    74
    I saw the video on YouTube and then came here for more information. Surprised that I haven't seen more discussion. Nice detail on how to modify the pump. Nice he can buy the ruby insert, but somewhere in the comments I saw something about the company only selling parts to existing customers of the commercial waterjet. I noticed he is always approaching from the side. I wonder if it can pierce cleanly?
    Oct 2016
    23
    He doesn't pierce because the sand would spray in his face if he did. What kind of control software and gantry is recommended to a hobbyist wanting to do this?
    May 2014
    97
    The WAZER doesn't seem economical at all. If you look at their feed rate, it can cut (max) .1875" mild steel at .4 ipm. It consumes .33lb of garnet per minute at ~$1.1 per pound.
    Imagine a simple part, say a single .1875 3 x 5" bracket with a few features, call it 35 inches of cutting. With piercing I image the cut time will be around 90 minutes. 33 dollars worth of garnet for a simple part. A 60k psi water jet could cut the part nearly two orders of magnitude faster. The same part is probably 2 minutes on a 100/hr. industrial machine. Just doesn't add up.
    I'm sure there will be some niche use cases, but it seems mostly like a bad deal.
    Oct 2016
    23
    I'll trust your math, but for hobby, the math looks attractive. Imagine that same simple part. It takes 2 weeks to get the first prototype cut and shipped to me from a machine shop. The part has a mistake, now the second one takes another 2 weeks. Then there is a design change, the 3rd one takes another 2 weeks. That's 6 weeks to do the same thing Wazer can do in one day. So I would argue that for a hobbyist, there is more value in a Wazer-like machine than a machine shop.
    Jul 2010
    46
    Quote Originally Posted by Eddard_Stark View Post
    Don't buy the garnet from them. It should be in the $0.17-0.35/lb. range if you buy enough. Enough may be half a metric ton however...
    Oct 2016
    23
    Recycling garnet is possible. Much of it never hits the material.
    Jul 2010
    46
    Good luck drying it out and separating it from the tiny material "chips". And the garnet that does hit the material has the sharp corners worn.
    For 20-25 cents a pound I'm using fresh garnet.
    Jun 2007
    74
    Too rich for me. I'll stick to using my CNC mill for metals. What would be really interesting would be if a water jet like this could use table salt as the medium or some other graded sand to be "cheap", just for cutting wood, and then mount the head in place of router on a Maslow CNC.
    Jul 2010
    46
    Where's all the water gonna go?
Page 1 of 2 12
  1. Minnesota Waterjet Shop Installs 3rd Jet Edge Waterjet System
    By Jetedge in forum News Announcements
    Last Post: 12-04-2012, 05:15 PM
  2. Waterjet cutting machine promotion of JETE WATERJET
    By livemott in forum News Announcements
    Last Post: 09-25-2011, 03:25 PM
  3. Replies: 0
    Last Post: 10-13-2009, 03:01 PM
