586,104 active members*
3,262 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Getting started, I have some questions ...
Results 1 to 15 of 15
    Dec 2006
    29
    Hi all ,
    I'm fairly new to this site and reading some of the intresting projects I got the bug and started building my first machine . I have some questions for you guys
    I bought 6' of Acme 1/2-10 lead screw, but machining it I noticed the metal is VERY soft , Should I use it like this ?
    I mainly want the machine to cut foam (lost foam casting) and maybe some wood what size stepper motors should I buy ? and where is a good place to buy them ?
    If you guys see anywhere that may be making a mistake I would really apreciate your advise
    Frank Martin
    Here are some pictures of my progress I hope to end up with a cutting area of 12" X12" X 2.5"
    Attached Thumbnails Attached Thumbnails cncDrawingweb.jpg   000_1520web.jpg   000_1519web.jpg   000_1518web.jpg
    Dec 2006
    29
    Well I made a little progress
    Finished up some of the table
    Made the electronics panel with a Xylotex 4 axis board and 2 solid state relays .
    I downloaded Mach3 and and hooked up the X and Y motors and everything was working perfect , I then got exited and started to hook up the Z motor and thats when the sparks started !! (flame2) .
    I forgot to turn the power off on the panel and two wires touched my table , needles to say I cooked the driver board .
    So I ordered another board
    Here are some pictures , The cables need a better solution
    Attached Thumbnails Attached Thumbnails 000_1608.jpg   000_1610.jpg   000_1611.jpg   000_1612.jpg
    Apr 2007
    323
    frank
    thats pretty much what im wanting to build...but i cant make up my mind ive looked at alot of machines ,your looks pretty close to what i wanna build ,i was wondering about flex do you have any way to test for flex along your x axis? and what size rods did you use...are they hardened rods?.. hope you can give us some pics of what ever you plan to cut with it..great lookin machine !!!
    Dec 2006
    29
    Measuring Flex with a dial indicator the Gantry Flexes .003" and returns to .001" . There is a small amount of hysterisis , but its better then I had expected.
    The Shafts I bought as a kit on eBay from these guys
    http://www.web-tronics.com/cncrodkit3.html
    They are 20mm ,16mm and 12mm
    The threaded stock I bought here:
    http://www.dependableacme.com/about.htm
    Glad you like the table , its been fun learning as I built it. I got another board from Xylotex and just bought the Mach3 software . I'll post some pictures of my test runs
    Frank
    Jun 2007
    44
    whats that made of? aluminium? and what size motor did you use??
    Feb 2006
    Hi, i'm new too!
    Hi there i've started a gantry type router, after collecting bits for 2 years i have finally started welding bits together. the plan is to have a tubular steel frame MIG and TIG welded and cross braced for total rigidity.
    The spec of the machine:
    3 Axis gantry miller with 280 x 900mm bed, 400mm Y travel, 1100mm X Travel, 400mm Z travel.
    I already have 6 x 12 x 600 x 4mm ballscrews for the Y and Z (2 spare), 1 x 25 x 1100 x twin helix imperial pitch ballscrew.
    the basic idea is to have the Y axis moving back and fore on the base of the machine, the X along the gantry as normal but for the Z axis the entire gantry will move up and down.
    The problem i'm going to have is counterbalancing the 30Kg mass of gantry and spindle motor. my first plan was to have cables and counterbalance weights on the side of the machine, but this wouldn't counteract the movement of the spindle. so i think i'm going to use pneumatic assistance i'm not quite sure how this is going to work out but i have some spare linear air actuators so i may as well try!
    I was very lucky to be in the right place at the right time, in work they were scrapping of some old SMT placement equipment and this had loads of goodies in it including a kollmorgen brushless servo motor and complete drive system, altogether is will make an awsome spindle drive at 1.3Kw position and velocity controlled very cool.
    The only bug bear is that the factory set limit on the motor is 1900 RPM the motor max is 3800 so i have to find a way to remove the speed limit.
    Does anyone have any experience of kollmorgen bds5 servo drives?
    Jun 2007
    44
    eddi
    mild steel?? very cool though moving the whole gantry. complicated. wtf!! do it! hope it works out
    i dont know sqat!!! will be asking dumb questions
    Dec 2006
    29
    Well I got it back running
    I've been playing with the Mach3 processor , What a buy !! . As I'm sure you guys already know Mach3 is great.
    I've also been trying out some of the sample CAM programs , this picture is a carving I did with Vcarve , its a neat program but the price is steap , I may still buy it .
    I am intrested in Solidworks to CAM if anyone has any cheap Ideas.
    Quote Originally Posted by FrankM View Post
    For 2.5 dimensions it is free to export your files as 1:1 drawings and save them as .DXF's. Then use cambam to generate gcode.
    Dec 2006
    29
    Quote Originally Posted by mvaughn View Post
    I can't save Solidwork files as DXF , I'm using Solidworks 2003 .
    BTW . i've been playing with CamBam also , I wish I knew enough to help with the development .
    Dec 2006
    532
    You might have to make drawing first, than you can save as .dxf Not too sure, but might work
    Quote Originally Posted by rustamd View Post
    Correct, make your part in solidwork oriented with x-y axis' then choose "file", "make drawing from part". You can then save the drawing as dxf. It seems a little counter intuitive at first, but it works very nicely once you get the hang of it.
    Also, when creating the drawing you may have the use a custom sheet size and use a 1:1 scale for your drawing.
    Dec 2006
    532
    1:1 almost always solves those mysterius "part too small" problems
    Dec 2006
    29
    Great, it is possible to save the Drawing as a DXF Thanks alot
    Dec 2006
    29
    Well I made the Y and Z a little different and made it alot more stable , I had all the parts anodized and here's how it looks now .
    Attached Thumbnails Attached Thumbnails 100_0005.jpg   100_0006.jpg   100_0007.jpg   100_0008.jpg
  1. CNC mill questions - thrust bearings, leadscrew mounting, general questions
    By tonofsteel in forum DIY CNC Router Table Machines
    Last Post: 02-03-2012, 10:42 PM
  2. It's started
    By Max-DK in forum CNC Wood Router Project Log
    Last Post: 02-04-2008, 03:45 AM
  3. getting started in CNC. need all the help i can get :)
    By slow_rider in forum Benchtop Machines
    Last Post: 10-22-2006, 05:42 PM
  4. Questions about getting started
    By tyler_derden in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-06-2005, 10:25 PM
  5. New and trying to get started
    By robe_uk in forum Mechanical Calculations/Engineering Design
    Last Post: 04-17-2005, 06:52 PM
