hi all! i cant seem to get the hobby cnc board to move my steppers. its the newest board with 200 oz-in motors purchased as a kit. running windows xp and mach 3. when i power on the cnc supply i can hear a "static" noise in the steppers. i've changed the lpt port config all around within xp and played with the settings in mach 3. when i set mach 3 to use the 0378, the software asks for a "emergency reset". if i change the settings to 0278 in mach 3, it will let me load some of the sample g-codes (example: arc cutter, circle cutter, etc.) and the software acts like it is moving the steppers but nothing happens. is there some setup step i am missing?
