586,117 active members*
3,510 visitors online*
    May 2015
    35
    adjusting turret
    I have an Okuma Cadet LNC 8. One of my young guys crashed a big drill and now the drill will not indicate back to concentric with the chuck. How do I realign? I'm pretty sure I have to remove the turret and adjust something.
    Aug 2013
    18
    Re: adjusting turret
    I've got an LNC 8 manual. I could scan that part of it, and email if it would help.
    Sent from my SM-G900R4 using Tapatalk
    Feb 2009
    6028
    Pull number plate off, loosen bolts for coupling and smack it back in with a dead blow. Cadets are done from the front, unless it's really crashed hard.
    Sent from my A3-A20FHD using Tapatalk
    Dec 2008
    3109
    Quote Originally Posted by underthetire View Post
    You may need to remove / replace the two taper pins
    ( normally, they are only used to get it close to inline, then removed & stored ...... not having the pins installed allows for the turret to slip easier, if crashed,...... so there is less damage to the machine components )
    ( pins can be left installed.... your choice )
  1. Replies: 26
    Last Post: 03-02-2023, 11:25 AM
  2. Aligning turret on a Daewoo Puma 10, 12 tool turret
    By AirChunk in forum Daewoo/Doosan
    Last Post: 06-03-2016, 02:37 AM
  3. Replies: 0
    Last Post: 09-30-2015, 08:03 AM
  4. Adjusting the Turret indexing
    By Snowie in forum Uncategorised MetalWorking Machines
    Last Post: 08-26-2010, 12:51 AM
  5. adjusting the turret on Conquest 42
    By dango in forum Hardinge Lathes
    Last Post: 11-05-2009, 04:41 AM
