587,036 active members*
2,847 visitors online*
    Oct 2016
    4
    Executing Auxillary Codes
    Hi All,
    I am on a waterjet milling project where any variations in the machine movement can result in deep/shallow spots. We currently have our jet/abrasives linked to Mcodes. When reading the mcodes the whole machine pauses momentarily, even with motion commands before and after the mcode. I need to find a way to keep the machine moving while turning the jet/abrasives on/off to avoid variations in the milling speed. Do I need to use a different type of command or is there a machine parameter I'm missing? Any suggestions are appreciated!
    We are running a fagor 8070.
    Thanks!
    Jul 2003
    1220
    Re: Executing Auxillary Codes
    Use look a head G51 at the beginning of your code.
    G51 E0.001
  1. x y setup for auxillary spindle
    By MFchief in forum Tormach Personal CNC Mill
    Last Post: 01-28-2020, 12:38 PM
  2. executing a program with sub
    By pbarry in forum Milltronics
    Last Post: 01-28-2011, 03:25 AM
  3. Auxillary I/O Adlink
    By davesnd in forum CamSoft Products
    Last Post: 07-12-2009, 11:04 AM
  4. HS1 horizontal mill with auxillary axis alarm
    By teal854t in forum Haas Mills
    Last Post: 04-18-2009, 06:47 PM
  5. AUXILLARY STEADY REST FOR PATRIOT
    By smallblock in forum Shopmaster/Shoptask
    Last Post: 04-17-2008, 03:50 PM
