586,121 active members*
3,415 visitors online*
Results 1 to 9 of 9
    May 2009
    393
    Not able to write macro on Fanuc OT Series
    I just wrote a macro Program on Fanuc Oi mate - TD control. The program works fine on Fanuc Oi Mate control.
    I also want to implement the same on my older machines which have Fanuc O T control.
    I am not able to type the following things on old control -
    1. #3000 = 1 (To generate alarm)
    2. #501 = #2801 (To copy geometry offset in common variable)
    3. If [#510 GT #509] GOTO 999 (This is the tool offset check condition)
    Please require assistance on how to write these codes on older machine or can it be accomplished by some other codes?
    Ashish
    May 2015
    70
    Re: Not able to write macro on Fanuc OT Series
    Is this because the controls don't have a full keyboard? If so, you can write the macros on your PC then transfer the program via RS-232 or Ethernet.
    Feb 2009
    6028
    You sure you have macro on the old control? Was an option back then.
    Sent from my A3-A20FHD using Tapatalk
    May 2009
    393
    Hey it that really possible? If I transfer that codes via RS232C port then can I really run the program on older machine.
    Get your CAM Programs rotated by CAS software to REDUCE SETUP TIME on your VMC & HMC. To download it, visit www.computeraidedsetup.com
    May 2015
    70
    Quote Originally Posted by Ashish B View Post
    If the control has the Macro A or Macro B option, yes.
    May 2009
    393
    How to check whether the machine supports Macro A or Macro B on my old machine?
    Jan 2016
    13
    In MDI type #100= 1
    If your machine alarms it can't read macros. I'm not sure about the difference between A & B. I work with YASNAC machines.
    Jul 2010
    118
    one of these examples will create a alarm
    Macro A format
    b)Addition #i = #j + #k
    G65 H02 P#i Q#j R#k;
    [Example] G65 H02 P#101 Q#102 R15 ; (#101=#102+15)
    Macro B format
    #100=#101+15
    May 2009
    393
    But how to type # or = character on the control
    As all can see in the attachment, I type the buttons below DELETE button, then is it not getting typed.
    That # character is only typed when I type certain alphabetical character such as A, B
  1. Replies: 4
    Last Post: 06-06-2023, 04:27 AM
  2. Replies: 17
    Last Post: 09-17-2015, 01:07 PM
  3. Replies: 3
    Last Post: 08-22-2014, 08:13 AM
  4. FANUC I SERIES, Macro?
    By BOATDUDEGUY in forum Fanuc
    Last Post: 10-24-2013, 11:07 PM
  5. Convert Fanuc Macro to Fadal Macro
    By bfoster59 in forum Fadal
    Last Post: 11-09-2007, 06:41 AM
