586,317 active members*
3,433 visitors online*
    Jun 2014
    777
    SFU nut and nema 34
    Thought id post this image for anyone considering using a 20mm sfu ballscrew and nut with an nema 34 8.1nm. This is the second nut the balls have worn their own grooves in. Think these are really only rated to 4nm.
    Re: SFU nut and nema 34
    Did you grease it regularly?
    Jun 2014
    777
    No grease. Found Grease clogs these up, even the lightest of lithium grease. Clogging destroyed the nylon ball return jumpers on the first one I had, on nut 4 now. They are now oiled automatically at the beginning of each day. I had run dti's up and down screw on various occasions to check for ballscrew alignment and it's very good. With new nut it's runs great, very quiet and friction free. The only cause I can see is the cheap Chinese steel it's made from and having a semi powerful motor on it.
    If the steel is too soft, then motor size is somewhat irrelevant. They'll fail with any size motor eventually, if the steel isn't the correct hardness.
    Jun 2014
    777
    Maybe thats what it boils down to, SFU nuts are rubbish plain and simple. 4 months contunous use 5 days a week seems to be the average life of one of these.
    When I complained to the shop they were purchased from they sent out 2 replacements which suggests its a known issue.
    Had a hard time replacing it to another more professional screw, had one turn up with two bends in, and another incorrectly machined, now out of stock indefinitely. Will need to source another screw and nut before the current one does the same. Hopefully I have more luck third time around.
  1. Stepper motor upgrade NEMA 34 or NEMA 42?
    By rogerfries in forum Bridgeport / Hardinge Mills
    Last Post: 07-28-2015, 04:59 AM
  2. Nema 17 Stepper motor on Nema 23 driver
    By Thomas T in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-21-2014, 08:59 AM
  3. nema 34 1600 oz or nema 42 3200 oz?
    By 15mgtar in forum Stepper Motors / Drives
    Last Post: 07-27-2009, 11:53 PM
  4. Standard Nema 34's vs Nema 34's with encoder/controller.
    By SCCoupe in forum DIY CNC Router Table Machines
    Last Post: 03-16-2006, 05:03 PM
