586,123 active members*
3,395 visitors online*
Page 1 of 2 12
Results 1 to 20 of 57
    Oct 2016
    12
    6040 CNC VFD settings?
    I have a 6040 CNC with the VFD and control box as shown in the attached photo. (mine has PRT-E1500W written above the LED display).
    Can anyone tell me what the program settings are for this VSD?
    I can't get the spindle to spin and I'm hoping that I may have accidently altered on of the settings.
    The codes are selected as a 'd000' type entry ('d' followed by 3 numerals) and then the number can be changed for that code.
    Here is what I have copied down from my VSD:
    VFD settings
    d000 = 50.0
    d001 = 0
    d002 = 000
    d003 = 00.00
    d004 = 220.00
    d005 = 00.0
    d006 = 110.00
    d007 = 00.50
    d008 = 001.7
    d009 = 00.00
    d010 = 00.10
    d011 to d018 = 10.00
    d019 = 01.00
    d020 = 10.00
    d021 = 50.00
    d022 = 0
    d023 to d030 = 0000
    d031 = 004
    d032 = 001
    d033 to d036 = 0
    d037 = 004
    d038 = 001
    d039 = 000
    d040 = 100.0
    d041 to d043 = 0
    d044 = 030.0
    d045 = 030
    d046 to d050 = 0
    15362
    Re: 6040 CNC VFD settings?
    Quote Originally Posted by RoddQLD View Post
    VFD settings
    d000 = 50.0
    d001 = 0
    d002 = 000
    d003 = 00.00
    d004 = 220.00
    d005 = 00.0
    d006 = 110.00
    d007 = 00.50
    d008 = 001.7
    d009 = 00.00
    d010 = 00.10
    d019 = 01.00
    d020 = 10.00
    d021 = 50.00
    d022 = 0
    d023 to d030 = 0000
    d031 = 004
    d032 = 001
    d033 to d036 = 0
    d037 = 004
    d038 = 001
    d039 = 000
    d040 = 100.0
    d041 to d043 = 0
    d044 = 030.0
    d045 = 030
    What is the manufacturers name of the VFD, you will have to open the case to see that and what size spindle do you have
    Mactec54
    Oct 2016
    12
    The unit has a warranty seal on the lid of the control box, so I am reluctant to open it (at this stage, just in case it's a warranty claim).
    The spindle is 0.8 kw water cooled spindle.
    If someone has the same control box as the one in the photo, and has the marking above the LED display (PRT-E1500W) and the same style of program code ('d' followed by three numbers) they might be able to note down the codes for me to compare with what I have in mine.
    Thank you for your response.
    15362
    You have no warranty, contact the seller and ask for a PDF file for the VFD, and Post it here, I could give you some numbers but from your list it's a bit of a risk, if you don't set the right Parameters, then you could fry the spindle motor or the VFD
    The number PRT-E750 is what is on the front keypad, does not match any of the more than 60 VFD manuals I have, Spindle spec's are no problem
    You will have to open your control box to check that the VFD is Grounded most are not, and this you have to correct/do
    Mactec54
    Oct 2016
    12
    Thanks for your reply. My item has a 2 year warranty from the importer.
    My spindle worked correctly from the front control panel when I first set it up. I may have accidentally changed a part of the program while I was setting it up to configure the axis controls and to have it operate with Mach3.
    I have contacted the importer/seller noting the problem that everything works except the spindle and have sent them a video of how I operate the machine as well as a screen print of each setting page. I have also given them the VFD settings that I have in my VFD so that they can check if they are correct and haven't been changed. They have been passed on to their technician so I wait. The seller has been very responsive and has replied to all my messages every time although there has been the odd misunderstanding.
    I see that there are some members here that have the same control box with PRT-E1500W written above the LED display (not PRT-750). If I can get a copy of the codes for that VFD then I may be able to compare and see what I may have altered.
    15362
    There is no such thing as a 2 year warranty, that would be honored in any way, that is just a way to get more sales, there warranty is as good as the paper it is written on, the number on the Key pad is what the VFD is, this key pad is from the front of the VFD Drive, the photo you posted is clear what the number is, PRT-750, unless this is not your photo, you need the name/manufacturer of the VFD then I could give you the correct Parameters, what you did that changed the Parameters was a Reset of the VFD and the Parameters are now at the Factory Default, which is not suitable for your spindle to run
    Mactec54
    Apr 2013
    1899
    WTF? You received no manual at all?????
    I would have sent back that box immediately. Without a manual you will not be able to keep in in the long run, you will eventually fry the controller or the spindle or both, so the first thing I'd do is DEMAND the seller to give me a manual. If he can't provide that within reasonable time (1-2 weeks) I'd claim my money back. 100% of the costs + shipping and whatever else is paid (import duties or other charges).
    Experimenting without manual will only result in failure unless you are lucky, so in my opinion, no point continuing without a manual. Perhaps it is already fried, but now that you have even admitted the seller that you have changed things and the box is no longer working, he will say that YOU fried it, it is your fault and that the warranty is no longer valid. So, in my opinion you should contact the seller once again, give him one week to send you a solution proposal for the right settings AND the manual so that in the future you can fix it on your own. If he is not delivering you must claim your money back including shipping costs back to him, BEFORE shipping it back to him. Otherwise you will never see your money or the box again, no matter how well organized the Australian consumer protection is.
    BTW, I agree with Mactec54, your parameters seems to be totally wrong, it looks like it is set up for 50Hz motor, but in my opinion, they look wrong even for that. Note that you cant just change every "50" to "400", that would probably not be a good idea unless you really know that you have to do it. There are other parameters also, like maximum current, RPM, power and so on. So, without a manual or another person having an identical box, I don't think you have a big chance of fixing this, especially since you don't seem to remember what you have changed and from which value.
    Look what I found by searching eBay:
    USB Port CNC Router 6040T Graviermaschine Fräsmaschine 1500W Spindlemotor VFD | eBay
    Here is another one:
    4Axis CNC Router 3040T Graviermaschine Fräsmaschine 800W Spindlemotor VFD Engrav | eBay
    Is this your machine? Contact the seller and ask if you can get a manual.
    24
    Can someone please post this VFD manual, or a link to it? I have exactly the same box, with the 800 w motor. This topic seems to be the only one google can find with the PRT-E750 number in it.
    thanks,
    Feb 2017
    5
    Has anyone got a copy of the PRT-750 vfd manual that they can forward on to me please?
    Hi everyone, I'm new to the forum and very poor with English.
    I am attaching the required manual and pose a problem on my 4030 4 CNC axes. After changing some settings not working longer and I had to reset to factory settings.
    Then i set D001 and D176 to 1.
    After i set D000, D002, D003, D009, D021, D93 to 400.
    D31, D36, D39 to 1 and finally D001 to 0 for the parameter block
    Now the spindle manually control works well on PC but when I switch the spindle starts, but always at 24000 rpm even though I Gcode imposed more low values (eg. M03 S4000 should run at 4000 rpm).
    If anyone has suggestions or other values to change would do me a great gift.
    I hope I have sent you the PDF manual, thanks
    15362
    Quote Originally Posted by windom46 View Post
    Try D108=4
    Mactec54
    Thank you for your response, I tried to set D108 on 4 but continues to run at 24000.
    I translated into Italian (with Google translator) the manual settings is the default ones that I set myself. I put it in the annex, if someone can tell me where I went wrong I will be grateful to him forever.
    Thanks, Domenico
    Attached Thumbnails Attached Thumbnails Spindle Setting.pdf
    15362
    Thanks, Domenico
    Put the D108=0 back to 0
    It seems that your control my not be doing an output for the speed control, check to see if you have 0-10 v that controls the VFD speed so if you put 12,000 it should read 5v, this could be just a configuration in your software, but check that the PWM output is working
    Mactec54
    Apr 2017
    7
    Thanks, Domenico
    Hello, i am new to the forum and i saw that you are italian, i call my fox,
    Sorry if i am disturbing but reading on the forum i saw that you have a cnc similar to mine and you have encountered problems like me.
    I wanted to ask you if you could help me.
    I have a 6040 with 4 axes with chinese prt-e1500w control, but for a while I can not do it anymore, I just pretend I do not understand
    Quanalche month I did this purchase.
    I just managed to do some small engraving with mach3 and just enough.
    Cmq i arrive then, i always have a problem with the spindle, if i try to spin the spindle in manual and i am zero machine works the spindle, spin, just
    I move with the axes
    And I try to turn on the spindle, it crashes everything and I'm mistaken "on the check comes E_o".
    I noticed that on mach3 I always have this message "pwm bumped to minimum setting error"
    What do you think?
    I also tried to reset the parameters (d176) to reset everything as it was at the beginning, but I did not get any results, but now the spindle nn runs just the most.
    I'm doing crazy !! i also followed the procedure provided by the seller but nothing
    I hope you can give me some advice.
    thank you
    Hello foo
    ciao , sono nuovo del forum ed ho visto che sei italiano, io mi chiamo pippo,
    scusami se ti disturbo ma leggendo sul forum ho visto che hai un cnc simile alla mia ed hai riscontrato dei problemi come ho io.
    volevo chiederti se potevi aiutarmi.
    io ho una 6040 a 4 assi con controllo prt-e1500w cinese, purtoppo da qualche tempo non riesco piu a farla funzionare ,premetto che ne capisco poco e da
    quanalche mese ho fatto questo acquisto.
    sono riuscito solo a fare qualche piccola incisione con mach3 e basta.
    cmq arrivo al dunque , ho sempre un problema col mandrino, se provo a far girare il mandrino in manuale e sono a zero macchina funziona il mandrino, gira, appena
    mi sposto con gli assi
    e provo ad accendere il mandrino mi si blocca tutto e mi da errore" sul controllo compare E_o".
    ho notato che su mach3 ho sempre presente questo messaggio "pwm bumped to minimum setting error"
    secondo te cosa puo essere?
    ho provato pure a fare un reset dei parametri (d176)per rimettere tutto come era all'inizio, ma non ho avuto nessun risultato, anzi adesso il mandrino nn gira proprio piu.
    mi sta facendo impazzire !!ho seguito anche la procedura fornida dal venditore ma niente
    spero che tu possa darmi qualche consiglio .
    ti ringrazio
    ciao pippo
    Ciao pippo73, ieri ti ho risposto ma sul sito non vedo nulla, non fa niente, provo a scriverti nuovamente.
    Allora...il PRT-E1500 come controller, dovrebbe essere impostato come il PRT_E750 ma pilota il motore da 1.5KW, il mio invece è da 800W.
    Fai attenzione che anch'io avevo fatto il reset di fabbrica dopo avere giocherellato con la tastiera (d176 impostato a 1 dopo avere messo d001 a 1) e per poco non bruciavo il motore. Un amico, che mi ha dato una mano a sistemare le cose mi ha detto che il motore veniva pilotato con una potenza di 8 volte superiore al necessario, infatti scaldava tantissimo e dopo un po' saltava il fusibile sul retro.
    Nel post 23 del 03/20/2017 e nel post 25 del 03/21/2017 (allegato) trovi le modifiche che io ho fatto al reset di fabbrica. A me così funziona benissimo, unica eccezzione la velocità di rotazione impostata da PC che anche immettendo da GCODE. ad esempio M03 S12000, il mandrino dovrebbe avviarsi a 12000 giri (così faceva una volta) , invece parte sempre a 24000 giri . Manualmente invece, nessun problema. Ho già cercato in tutti i siti Italiani che trattano CNC in modo da poter confrontare i 179 parametri delle macchine vendute nel nostro paese ma sembra che le uniche due macchine vendute in Italia, siano le nostre.
    Mach3 io l' avevo impostato come spiega il manuale allegato alla macchina e funzionava. Il mio problema era che non mi finiva i lavori, ad un certo punto si fermava e non voleva saperne di continuare, ora uso LinuxCNC e più nessun problema.
    Secondo me poi, l'errore che ti da sul mandrino è solo questione di impostare i parametri corretti, specialmente d000,d002,d003,d009,d0021,d093 che io ho a 400.
    Se potessimo sentirci forse riusciremmo a concludere qualcosa di più ma non so se si possono mettere i numeri di telefono, spero comunque di esserti stato di aiuto, ciao.
    Apr 2017
    7
    Most that buy these machines would not be able to check what Parameter, are set in there VFD, and would not know how to even go about getting them, they to could mess up there settings very easy
    Apr 2013
    1899
    Quote Originally Posted by bewerbung View Post
    That is always the case for everything we buy. Some people are not even able to configure a TV but that does not excuse manufacturers from making and delivering proper manuals about how to configure. It is better to have access to a manual than not. After that it is up to you to read it or to ignore it, but if you don't have a manual then you really can't do anything, even if you'd be capable with the manual.
    Jun 2017
    29
    VFD settings
    d000 = 50.0
    d001 = 0
    d002 = 000
    d003 = 00.00
    d004 = 220.00
    d005 = 00.0
    d006 = 110.00
    d007 = 00.50
    d008 = 001.7
    d009 = 00.00
    d010 = 00.10
    d019 = 01.00
    d020 = 10.00
    d021 = 50.00
    d022 = 0
    d023 to d030 = 0000
    d031 = 004
    d032 = 001
    d033 to d036 = 0
    d037 = 004
    d038 = 001
    d039 = 000
    d040 = 100.0
    d041 to d043 = 0
    d044 = 030.0
    d045 = 030
    d046 to d050 = 0
    Here try these codes, let me know how it works out, its what I get from my supplier, Her name is Rose, and she doesn't work weekends lol this is why I came here. You might be able to reprogram your toaster?
    Jan 2016
    4
    Hey guys, thanks for posting the PDF version of the manual. It makes things much clearer.
    CHIMERA1960, you said you had contacted a manufacturer of the board and that they were in Singapore. Can you tell me about this VFD board maker? I'm interested in the RS485 aspects of the board, and the manual isn't too detailed. For more info on RS485, it says to contact them on their "website", which obviously isn't linked in the document.
    Is it the same boards as the JD inverter that windom46 posted the manual for?
Page 1 of 2 12
  1. New 6040 CNC machine. Spindle controller settings.
    By RoddQLD in forum Australia, New Zealand Club House
    Last Post: 05-29-2018, 08:29 AM
  2. yoocnc 6040 s80 settings
    By RABBIDUS in forum Mach Software (ArtSoft software)
    Last Post: 04-12-2013, 08:32 PM
  3. Mach3 CV settings vs. G-100 Plugin CV settings
    By Bfarn in forum Machines running Mach Software
    Last Post: 12-17-2008, 05:45 PM
