586,082 active members*
3,772 visitors online*
Results 1 to 6 of 6
    Jan 2007
    50
    small part need quote 300 pcs.
    hello all after the great reponce i got i thought i would give it another go
    here is a small part i need a quote on for 50,100,and 300 parts the thickness is .118 but .125 is fine the parts will need to be cad plated. need the quote by 2/9/07 job will be handed out the following monday with a two week turn around time
    thank you
    joe
    Attached Files Attached Files
    Jan 2007
    50
    sorry yes they are 45 deg and the dim is .177
    Nov 2006
    27
    Hello, would you be willing to put this up in a pdf, bmp, or jpeg format? I have trouble opening dxf as of late...
    Has this job been sent out or are you still taking quotes. Please advise.
    Feb 2006
    42
    Have you awarded the job yet?
    Jan 2007
    50
    still taaking bids i am waiting on the po to run the job it should have been here monday BUT with all the snow we got things were shut down for a few days, also i small side note they can be made from 301 stainless steel and no cad plating
    thanks
    joe
  1. RFQ - CNC part prototype / small run
    By MrTman in forum Employment Opportunity
    Last Post: 02-27-2006, 10:17 PM
  2. Quote for Simple Aluminum Tubing Part
    By BrianTx21 in forum Employment Opportunity
    Last Post: 02-04-2006, 05:49 PM
  3. Small part favor for a friend
    By pyrojon in forum DIY CNC Router Table Machines
    Last Post: 01-20-2006, 03:24 PM
  4. RFQ- small little round part needed
    By fastolds in forum Employment Opportunity
    Last Post: 12-07-2005, 02:04 PM
  5. RFQ Small part
    By impact in forum Employment Opportunity
    Last Post: 02-14-2005, 09:05 PM
