586,080 active members*
3,782 visitors online*
Results 1 to 13 of 13
    Aug 2013
    8
    Kflop + stepper motor axis drifts
    Need help. I have Kflop + driver 2MA860H + stepper motor. Moves axis 10 times back and forth for 1 mm. Result - axis drifts in the negative direction by 0.1 mm.
    Reverse wires on the stepper motor axis began to drift in the positive direction.
    Regards Constantin.
    May 2006
    4045
    Re: Kflop + stepper motor axis drifts
    Hi Constantin,
    That is often caused by insufficient Direction Setup Time. Try setting the pulse time to maximum 3.78us and try inverting the Step Pulse Polarity. See the example:
    SetStepPulseLength.c
    and also:
    Step and Direction Setup
    Regards
    TK
    http://dynomotion.com
    Aug 2013
    8
    I did as it is written in the manual. I added a line to the FPGA initsaalizatsiyu (STEP_PULSE_LENGTH_ADD) = 32;. But the driver did not respond. I increased the number to 39, and the driver began to move. But there is a drift in the negative direction. The problem kflop. I changed the wires on the stepper motor and drift became positive
    May 2006
    4045
    Hi Constantin,
    The timing must be set properly for your drives.
    Try the maximum value of 63.
    If there is still drift then try inverting the pulse by adding 0x80
    FPGA(STEP_PULSE_LENGTH_ADD) = 32 + 0x80;
    Regards
    TK
    Aug 2013
    8
    I did all this. Experimentation has shown that a maximum of 70. But the drift is not disappeared. I tried FPGA (STEP_PULSE_LENGTH_ADD) = 32 + 0x80; But the dead driver. Begin to move with FPGA (STEP_PULSE_LENGTH_ADD) = 39 + 0x80; But the drift still remains.
    May 2006
    4045
    Hi Constantin,,
    My mistake. The maximum value is 63. Try
    FPGA(STEP_PULSE_LENGTH_ADD) = 63 + 0x80;
    and
    FPGA(STEP_PULSE_LENGTH_ADD) = 63;
    What Version of KMotion are you using?
    Regards
    TK
    Aug 2013
    8
    Quote Originally Posted by TomKerekes View Post
    Hi Constantin,,
    and
    Regards
    KMotion Version 4.33
    May 2006
    4045
    Thanks.
    Did you try those two settings individually?
    Regards
    TK
    Aug 2013
    8
    Not yet. Today, I will try.
    Aug 2013
    8
    Thanks.
    Regards
    Hi Tom.
    Today I tried - a negative result. The drift continued.
    I have 2 axes X and Y stepper motors and a Z-axis servo drive.
    On the axis Z drift absent.
    What else can you recommend?
    Regards Constantin.
    May 2006
    4045
    Hi Constantin,
    Are you sure you tried both of those settings correctly? Please post the two C programs you tried.
    How are the Step/Dir Signals wired? How long are the cables?
    How did you configure the KFLOP Axes?
    What are the specifications for the Z axis Step/Dir signals?
    Regards
    TK
    Aug 2013
    8
    Hi Constantin,
    Regards
    Hi Tom.
    I have a Chinese 4-axis machine through Ncstudio. We changed management to kflop + konnect. X Y stepper drive Z A servo drive. Step / Dir Signals wired. Length 0.8 m
    I changed the speed and acceleration but drift left.
    I inverted the wires on the stepper motor - the result changed the direction of the drift.
    Regards Constantin.
    May 2006
    4045
    Hi Constantin,
    The Init Files are correct. I assume you ran them right before doing your test?
    I was hoping you would include details of how you wired the Step/Dir signals. Did you connect +5V from KFLOP JP7 to the +DIR +Pulse signals on your drives?
    Otherwise if you happen to have an oscilloscope you might verify that the Direction and pulse timing from KFLOP is correct.
    I believe the drive specifications for voltage levels of the Step and Dir inputs are > 4.5V for on and less that < 0.5V for off. KFLOP meets the spec of >4.5V but only about 1.2V for off (internal protection diode to 3.3V supply limits pin to ~ 3.8V). I have never seen this to be a problem as most LEDs require at least 1.4V to turn on even without any series resistance.
    You might check the voltage levels across the Drive Inputs with a Voltmeter. On KFLOP Power up the pins should be inputs "Open" and you should see 1.2V or less on the drive. Then use the Digital I/O Screen to set the Pins (Bit 8 and Bit 9) as an output and low. The voltage at the drive should then be 4.5V or more.
    You might also check your +5V supply.
    You might add a Line Driver module to make sure it isn't a voltage level issue. Such as:
    https://cnc4pc.com/differential-line-driver.html
    Regards
    TK
  1. best Big stepper motor work with Kflop+Kstep?
    By mismis in forum Dynomotion/Kflop/Kanalog
    Last Post: 09-19-2012, 04:16 PM
  2. x axis drifts when shut down Nakamura
    By partfinder2 in forum Uncategorised MetalWorking Machines
    Last Post: 05-11-2011, 06:29 PM
  3. x-axis drifts to the right???
    By dlh422 in forum CNC Machining Centers
    Last Post: 04-10-2006, 09:14 PM
