if I was to bore a piece of material from say 18 inches to 20 inches and it already had a 18 inch hole in the stock. How in the world can I draw that stock with
an 18 inch hole already in the stock? thank you
2016 2D on the lathe. when I run a simulation it doesn't show a hole already there so my toolpaths don't compute
For some reason when I try that it doesn't seem to draw the part with a hole already in it. leaving all the rough pass paths from x0 to x18 to be cut
yeah its still not allowing me.
so if I create another workgroup and call it stock then draw two holes and they are AIR how do I connect those to show theres a hole already exist
"so if I create another workgroup and call it stock"
I believe that method would only work if you want to make stock without holes/pockets in it.
I would create a solid part that represents your stock, then right click it. Under properties, select 'Stock' for body type.
I don't understand, I can draw it fine if im using the 3 axis mill the stock is perfect. if I switch to a c-axis lathe it goes to crap. lol
Mactec54
GOOD thought ill try it
