586,117 active members*
3,326 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Arrow 500 Acramatic 2100 X AXIS TPA/HOME FAILURE
Results 1 to 7 of 7
    Oct 2016
    Hello all,
    This is my first post after registration, asking for any help I can get on this.
    Arrow 500 with Acramatic 2100 control had a new main board change recently and is getting " X AXIS TPA/HOME FAILURE I'm thinking this is a parameter issue. Manuals don't offer much help, any assistance would be greatly apprieciated.
    Dec 2006
    584
    Re: Arrow 500 Acramatic 2100 X AXIS TPA/HOME FAILURE
    Does the table move to the right or the left when aligning?? Did you back up the parameters prior to putting in the new main board?? What do you mean by a new main board?? Which board did you change and why??
    Mike CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Oct 2016
    Quote Originally Posted by meckardt55 View Post
    Good Morning Mike,
    Thank you for responding so quickly. I had wrong information, my boss just told me he had the hard drive replaced and cloned from the old hard drive, I don't know the circumstances which led up to the hard drive replacement. The X Axis moves from left to right when aligning. Again thanks for your help.
    John Wilson
    Dec 2006
    584
    So do you have a problem with the machine???
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Oct 2016
    Yes Still getting X AXIS TPA/HOME FAILURE
    Jul 2015
    Hello,
    I've gotten this alarm on arrow 500 and the problem was in the wire from X home switch and was necessary replace it. Maybe you can check the status of switches and voltage, when the switch is pressed you would have 24vdc out and 0 V when is release.
    Aug 2017
    16
    [CITA = meckardt55; 1950042] ¿Entonces tienes un problema con la máquina?
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services [/ CITA]
    hi ineed help.
    Acramatic 2100, alarm 44-6
    falla alineacion de grilla de eje z
  1. Acramatic 2100 Arrow 750
    By renaissance1703 in forum Cincinnati CNC
    Last Post: 07-16-2016, 03:15 PM
  2. Cincinnati Arrow 750 with Acramatic 2100...
    By Trigg in forum Cincinnati CNC
    Last Post: 04-29-2015, 10:18 PM
  3. Acramatic 2100 failure & spindle peobs
    By Doug E Stop in forum Cincinnati CNC
    Last Post: 09-09-2013, 04:11 PM
  4. arrow 750 Acramatic 2100
    By 1234567 in forum Cincinnati CNC
    Last Post: 11-09-2011, 06:53 PM
  5. Acramatic 2100 Arrow 1000 need help
    By griz-shop in forum Cincinnati CNC
    Last Post: 12-06-2008, 07:49 PM
