586,112 active members*
2,999 visitors online*
Results 1 to 9 of 9
    Apr 2015
    17
    Cool Low Pressure is not working
    is there anyone know the solution why the Low Pressure is not working?..
    Sep 2010
    72
    Re: Low Pressure is not working
    Machine: make, model?
    Material: type, thickness, state?
    Mode of failure: won't cut with low pressure, won't switch to low pressure, etc.?
    Please provide more information ...
    Apr 2015
    17
    it's a waterjet cutting machine from cms technocut, it's a 2005 model..the problem that I'm dealing now is that emulsified oil and the low pressure is not working when I'd switched from high pressure to low..any idea what might be the cause of the problem?.
    Apr 2015
    17
    @KilrB thanks for your reply Sir
    Apr 2015
    17
    Machine name is: Tecnocut made 2004
    Material: all types of steel, marbles or tiles or wood and cardboard up to 200 mm thickness
    Mode of failure: low pressure is not functioning
    Mar 2016
    59
    emulsified oil? As in hydraulic oil and water mixed?
    Apr 2015
    17
    Yes Sir, the water is mixing with oil
    Sep 2011
    9
    can you send your machine picture ?
    Apr 2015
    17
    Quote Originally Posted by qokhanyilmaz View Post
    You can find here the attached picture of the machine:
  1. Conquest almost working - no hydraulic pressure
    By rcpaisley in forum Hardinge Lathes
    Last Post: 09-06-2019, 06:27 AM
  2. What is the difference between wood working and metal working routers?
    By LaughingJaguar in forum Joes CNC Model 2006
    Last Post: 10-17-2016, 07:29 PM
  3. Switch view between machine working enveloppe and job not working?
    By skillalot in forum Screen Layouts, Post Processors & Misc
    Last Post: 08-10-2015, 03:55 PM
  4. Leblond / Fanuc OM Lube Pressure No 2050 Oil Pressure Alarm
    By alcarinc in forum Uncategorised MetalWorking Machines
    Last Post: 01-13-2015, 03:02 AM
  5. Replies: 0
    Last Post: 11-25-2013, 06:54 AM
