586,080 active members*
3,616 visitors online*
View Poll Results: How old are you?
Voters
2794. You may not vote on this poll
  • Under 20
    117 4.19%
  • 20 to 29
    642 22.98%
  • 30 to 39
    677 24.23%
  • 40 to 49
    622 22.26%
  • 50 to 59
    444 15.89%
  • 60+
    292 10.45%
Page 21 of 22 1119202122
Results 401 to 420 of 428
  1. #401
    Sep 2006
    245
    Re: How old are you?
    I am surprised that 75% of the votes are under age 50. I am in a woodworking club with about 100 members and it seems that only around a dozen of us are under 60.
    Steve
  2. #402
    Jul 2016
    660
    im 38 on this forum, I tricked it that way cause im sick and tired being young and banging teenage girls, to cut the story short I got bored being young, in reality im 28 :tired:
  3. #403
    Quote Originally Posted by steve323 View Post
    Steve
    I was in my early 40's when I voted, but I'm over 50 now.
  4. #404
    I'm too grouchy to go anywhere.
  5. #405
    or old enough to have Alzheimer
  6. #406
    Does it count if my 20th birthday was 2 days ago?
  7. #407
    Maximum no of person on this forum are between 30-39 age group ..
  8. #408
    May 2006
    803
    Who is the oldest ?
    Who remembers punched cards, 1" analog Ampex 9 track tapes real time with vacuum tubes controls machines?
    We made first parts of the DC-10, C5a, Shuttle on these,
    waaay back when only the airforce could afford NC..
    Wow we have come a long way since.
    70 &1/2 and have keys to the shop...........
    Just a hobby now used to be a pro...
    Been doing this too long
  9. #409
    Mar 2007
    463
    I remember most of that, but you are wrong, the Navy could afford them TOO! I helped install an NC mill on Mare Island Naval Shipyard in 1965. I had the keys to the shop before I retired in 2005, now all I have is my home shop with a CNC mill a lathe and a Bridgeport W/ digital readout.
    Larry
  10. #410
    Human become complete at the age of 40
  11. #411
    Oct 2015
    4
    Happy to say, cut my teeth on Allen Bradleyand GE1050 CNC controls, loved Octal notation and Multiplex troubleshooting, alwaysremember tape readers, you can put the bulb in upside down!! It won’t work LOL.:cheers:
  12. #412
    Nov 2013
    152
    Speking of Alzheimers. There is a protest group whose chant is " What do we want ? Don`t know ! When do we want it ? Want what ?????
    The only upside is that everything is new !!
  13. #413
    Jul 2016
    108
    With Regards / 1991/08
  14. #414
    Jul 2016
    108
    Wow, fantastic Sir.
    A Pro is always a Pro. We pride of that to have you here Sir.
    With Regards
    Who translate that punched tapes into 2017!
  15. #415
    Mar 2007
    463
    Quote Originally Posted by Russell840 View Post
    Wow, fantastic Sir.
    With Regards
    I can remember translating tapes many years ago, but with the new machining methods we have now it's better just to just use the blueprints redraw in a CAD program and go from there.
    I remember when all the programs were tool path and you HAD to use the right size tool to get a part that had the right dimensions. Now you have tool offsets right on the machine and the tool dimensions can be adjusted for. Back when tapes were punched you had to program toolpaths from point to point and if you went around a corner you had to choose the type of corner you wanted (sharp, rounded or just remove the sharp edge with a .005" 45 deg nick) and then calculate the tool path to make it. To round a corner you needed to figure out where the cutter needed to stop going straight and then where it would end up after going around the corner plus where the center of the arc was from where you stopped going straight. Now you can just tell the CAD program to round all corners and you are done. If you want to try something fun program the rough and finish cuts for a pocket shaped like a triangle (3" length down one side - point to point) with none of the sides either horizontal or vertical, do a step over of 75% and leave .02" for finish using a .125" end mill.
    Larry
  16. #416
    Nov 2012
    145
    There are 64 rings around the bathtub!
  17. #417
    Jul 2016
    108
    Well, I am repairer and need to translate punched tapes to export the old machines parameters and machine Data, sometimes PLC. It's sometimes floppy disk, 5inch, 3.4 inches, punched tape,
    It is the basic and I am in believing that, when someone works and learn basics, can be the better creator and problem solver.
    With regards Dear Larry :-)
  18. #418
    Mar 2004
    761
    60. Programmed NC machines using paper tape from a friden flexowriter for the EIA machines and a teletype model 33 for the ASCII machines. Lots of chad on the programming floor.
    Wayne Hill
  19. #419
    Jan 2008
    60
    I was in a different bracket when the poll was started than I am now.
    36 years young and taught by old schoolers.
  20. #420
    Wow, there are people of all demographic groups here.
