586,110 active members*
3,150 visitors online*
    Feb 2011
    353
    eccentric turning
    i have seen the you tube videos from citizens turning a eccentric shaft but is it possible to turn a hex doing the same type of programming
    I am running a citizen A-32-7 mitsubishi control with no live tooling on the sub the only live tooling that i can use is the 4 rotary's from the main tooling arm of the machine
    max degrees per minute would be 22000 or about 60 rpm on the sub c axis
    Sep 2011
    261
    Re: eccentric turning
    Why not just mill the hex with the main tools on the sub spindle? you just dont want to sacrifice the cycle time?
    CNC Product Manager / Training Consultant
    Feb 2011
    353
    i figure the cycle time on the front is going to be about 3 1/2 minutes with out the hex being milled with no machining on the sub spindle
    this would keep the cycle time to the 3 1/2 minutes instead of increasing it to mill it with the main spindle rotary tools
    Oct 2007
    88
    The short answer is, Yes. Use Polar Milling G12.1 and a top notch groove tool. The problem you may run into is Tool Life and C axis actually can stroke out. Let me knw if you need any more info
  1. Okuma eccentric turning (camshaft)
    By Lary in forum Okuma
    Last Post: 09-26-2023, 11:21 AM
  2. How to do eccentric turning in FeatureCam?
    By miki2432 in forum FeatureCAM CAD/CAM
    Last Post: 03-29-2021, 08:20 PM
  3. Programming for Eccentric Turning...
    By Jashley73 in forum Okuma
    Last Post: 07-20-2018, 09:14 PM
  4. How much eccentric it is ?
    By Ashish B in forum Hobby Discussion
    Last Post: 04-30-2012, 09:24 AM
  5. Eccentric Turning on LB 300
    By jimmyjolly in forum Okuma
    Last Post: 03-17-2010, 05:40 PM
