586,633 active members*
2,958 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > v26 measure entity and two entity doesnt display anything...
Results 1 to 12 of 12
    Oct 2007
    446
    Question v26 measure entity and two entity doesnt display anything...
    the tabbed window changes but only display a cancel button...there are no measurements of any kind displayed there....am i missing something here? is there a way to reset the default UI??
    Apr 2009
    3376
    Re: v26 measure entity and two entity doesnt display anything...
    are u measuring "entities" ?
    Can you snap a screen shot of an example ?
    Jun 2008
    1838
    Quote Originally Posted by airbrush View Post
    The Data is not shown in the pane with the "Cancel" button in it
    You need to place your cursor on a blank area of your mail menu toolbar and right click, on the list that will appear you need to look for "Measure Entity" and it will probably be "unchecked", if so left click on it and a "check" tick should appear,it is now "enabled"
    So now when you use the "Measure Entity" facility a new pane will appear with all the entity data in it, you can "drag" that pane to anywhere in your CAD area as shown
    See attached image
    Attachment 336736
    Regards
    Rob
    :rainfro: :rainfro: :rainfro:
    Oct 2007
    446
    Quote Originally Posted by The Engine Guy View Post
    See attached image
    Attachment 336736
    Regards
    Rob
    hmm...mine is checked but its not visible anywhere....the pane
    Jun 2008
    1838
    Sounds like it has been dragged somewhere accidently, by default it would normally appear on the bottom left of your screen, below the "Layers, UCS, Posting" tab, try dragging that pane up or down.
    Also look at the sides as it may have been "unpinned" which means it is hidden at the side.
    Upload a screen shot with the "Measure Entity" checked as when that is checked the data pane should be permanently showing. What Build number of V26 are you using ?
    Regards
    Rob
    Oct 2007
    446
    not at home right now to try...will have to take a look at it later and figure out where it went...
    Jun 2008
    1838
    Forgot to say, look around for a Blue ? mark on the left or right side as shown on the right of the attached image.
    Attachment 336742
    Also make sure that your screen resolution is correct and you have all of the BobCAD screen showing, it may just be hidden that way
    OK, later
    Regards
    Rob
    Oct 2007
    446
    this is what my screen looks like...no question mark...measure entity is checked...but not visible anywhere...can't seem to get it back
    Short of an uninstall and reinstall i have no idea....
    Attachment 337302
    Apr 2009
    3376
    you got your measure entity box "pinned"
    Oct 2007
    446
    Quote Originally Posted by jrmach View Post
    unpinning it still doesnt show me any measure tab/window...just collapses all of that over to the side of the window
    Oct 2007
    446
    found it..
    hooked up a second monitor (dual monitors)...i never run it with two monitors...found it fullscreen on the other monitor...dragged it back over to my main window.....
    Jun 2008
    1838
    Aha, I thought it might be that
  1. Entity does not lie in plane of CPL
    By jackdaniels91 in forum EdgeCam
    Last Post: 02-22-2015, 05:01 PM
  2. Exploded Entity
    By RAF. in forum BobCad-Cam
    Last Post: 09-09-2014, 06:38 AM
  3. Lost measure entity data box BOBCAD V23
    By sully31 in forum BobCad-Cam
    Last Post: 02-12-2014, 03:31 PM
  4. Trim 2 entity
    By dougmontgomery in forum BobCad-Cam
    Last Post: 03-10-2013, 02:30 AM
