586,756 active members*
7,872 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Materials question: MDF vs. tempered hardboard
Results 1 to 7 of 7
    Oct 2016
    3
    I have seen a few DIY's that use MDF for various parts. plates. and assemblies. How does 1/4" tempered hardboard stack up against 1/4" MDF? Any experience with these 2 materials?
    Thanks for any input you may have!
    Thinking newbie
    35538
    Re: Materials question: MDF vs. tempered hardboard
    MDF is stronger.
    But unless you are laminating to make thicker material, I don't know where you'd use 1/4" MDF for machine parts.
    Oct 2016
    3
    Thanks!
    Jun 2012
    817
    1/4" double tempered hardboard is much stiffer than 1/4" MDF. I've used it for rocket fins. The MDF would have shredded for sure.
    May 2005
    3920
    Quote Originally Posted by KerryR View Post
    Thinking newbie
    These are two entirely different materials, frankly I wouldn't use either for a machine tool build of any size. Unless maybe it was for demonstration or extremely light duty. In a nut shell neither 1/4" MDF nor tempered hardboard is stiff enough at least for machines e would be calling routers. My guess though is that tempered hardboard would hold up better as I use it for bench tops, storage boxes and the like where I really doubt MDF would hold up well at all.
    As for MDF it is a very capable material if you like working with it. I don' t like working with MDF (dust) so I avoid it as much as possible but smaller router type machines are very possible with MDF. That is if you base you project around at least 3/4" stock doubling it up in places and building box beams in other places.
    For most people though I suggest that they consider steel tubing for their machine designs. This especially if you can source steel at less than retail prices. The usual places to look for cheaper steel are junk yards, steel vendors selling drops and machine/fabrication shops.
    In any event tell use what you are thinking about building. Knowing what the application is has a big impact on how people will suggest alternatives.
    Jun 2012
    817
    Quote Originally Posted by wizard View Post
    Agreed, but I suppose a laminated beam of double tempered masonite might be really dense and stiff. It would be a lot of effort for questionable results though.
    May 2005
    3920
    Quote Originally Posted by Devastator View Post
    It wouldn't be the first time I did something the hard way. I've used masonite and also hardwood plywoods, such as Baltic Birch, Apple Ply and such. Frankly if I really wanted to build a small light weight machine I'd go with the plywood even though it is far more expensive than the masonite. For one I know that the plywoods can be glued and have joints that can be relied upon. Plywood also holds screws and inserts better.
  1. Etch tempered glass?
    By Bsrlinmaz in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-22-2015, 06:10 PM
  2. Materials Question
    By Rickyg in forum Material Machining Solutions
    Last Post: 07-09-2013, 09:24 AM
  3. Tempered hard board
    By swilliams in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-06-2012, 01:37 AM
  4. Hardboard Bit Advice? (rookie)
    By jbeuckm in forum CNC Tooling
    Last Post: 09-27-2011, 02:37 PM
  5. RFQ Hardboard screen covers
    By freecncplans in forum RFQ (Request for Quote)
    Last Post: 06-08-2011, 01:46 AM
