586,060 active members*
4,455 visitors online*
    183
    Backlash Question
    Ok if i put a diage gauge on my mill test 0" -> 1" -> 0" i can get the backlash right down, but my question is this if i do a 0" -> -1" -> 0" it doesn't match ???
    Is this normal?
    4826
    What kind of screw and thrust bearing are you testing? Is this a precision ground ballscrew and precision thrust bearing block?
    There are certainly instances where screw wear needs to be mapped for different positions along its length. A cnc controller then automatically adjusts the backlash for additional error due to non-periodic wear of the mechanical components, and these adjustments would be location specific on the machine.
    183
    using acm, non ground ... so i gues the best bet is to start at one end with a dial and go 1/2" by 1/2" and map the values?
    183
    Ok if i take out backlash move left by 0.1" my dial indicates 0.982" i can repeat this quite close, so is this screw mapping or steps per inch??
    10tpi screw microstepping 1/16's 32000 steps , i get different results on the x and y
    4826
    If it seems to be relatively uniform everywhere, then .018 would be the backlash setting. That is a very large amount for a 10 tpi screw. I would make every attempt to eliminate looseness in all thrust shoulders, and maybe make a springloaded nut, in an attempt to keep the screw bearing always on the same side of the nut. A new, tighter nut would also be good, or a double nut, with a fixed shimmed distance between them. You should be able to reduce a uniform backlash down to a thousandth or two.
  1. Servo idea - elimated backlash - zero backlash !
    By synthetiklone in forum Linear and Rotary Motion
    Last Post: 12-06-2006, 08:35 PM
  2. Backlash Question
    By Kazsaw in forum Haas Mills
    Last Post: 08-14-2006, 11:03 PM
  3. Backlash Question
    By scratch_6057 in forum DIY CNC Router Table Machines
    Last Post: 06-15-2006, 09:32 PM
  4. Backlash Question. V4.0.1
    By BMaynard in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-12-2006, 12:38 PM
  5. backlash question
    By arsenix in forum Bridgeport / Hardinge Mills
    Last Post: 11-01-2005, 07:25 PM
