586,283 active members*
4,288 visitors online*
Thread: Solidcam bug
Results 1 to 13 of 13
    Mar 2011
    68
    Solidcam bug
    Hello,
    I installed Solidcam 2016 SP0 and I have next problems:
    1.When generate multiple split operations, it generate: filename-1-1, filename-1-2, and so on, untill now it was filename-1, filename-2, and so on
    2.Limited filename lenght, I also modiified the PRC file with max_g_name_lenght=0 and still not works.
    Anybody have this problem?
    How can I resolve this?
    Thank you!
    Oct 2013
    153
    Re: Solidcam bug
    Update to SP2 it's better . And you have an option of using the split name as file name ! Just go through the settings
    Mar 2011
    68
    Re: Solidcam bug
    Quote Originally Posted by imachining-6061 View Post
    Hello,
    I've allready made this checks and split name as file name is disabled.
    I think is a bug of SP0.
    I will try SP2 and see if the problem is solved.
    I will come back with answer.
    Thank you.
    Oct 2013
    153
    Re: Solidcam bug
    Sp0 has a lot more bugs too it's safe to update to sp2
    Mar 2011
    68
    Re: Solidcam bug
    Hello,
    I installed SolidCam 2016 SP2HF3, and having not this problem anymore.
    What I can not resolve is that when I generate the g-code, the name of the codument is without spaces.
    What can I do to resolve this problem, because I can have g-code file with info in name like - 123 with clamping on 2mm - gcode name is 123withclampingon2mm.
    I also have:
    max_g_name_lenght = 0 in PRP under ;Internal params
    Even if I generate a splited operations even if I generate one operation I have same problem.
    Anybody with sollution?
    Thank you!
    EDIT:
    Found the solution with the spaces in name, in machine option(VMID file) in tab Working Style, at Gcode Output is a setting with Allow Spaces in Gcode File nad modyfied to YES.
    The problem is another one, after changing this setting, the partname in splitted files is again ti filename-1-1; filaneme-1-2 instead filename-1, filename-2.
    Anybody with solution for this?
    Even if I put back No to that setting the problem is not solved!
    Anything else?
    Thank you.
    Mar 2011
    68
    Re: Solidcam bug
    Also is any solution to disable last position in operation when using save cand copy?
    Thank you.
    Mar 2011
    68
    Re: Solidcam bug
    Quote Originally Posted by claudiu220405 View Post
    Hello,
    I also have:
    Thank you!
    EDIT:
    Anything else?
    Thank you.
    SOLVED!!!
    At the begining of the operations, i added "Machine Setup", and now everything is working good!
    Hope I helped somebody!
    Oct 2013
    153
    Re: Solidcam bug
    SOLVED!!!
    Just for your info
    In solidcam2016 machine setup also affects your Gcode generation. Especially if you are using a 4-axis or more . You need to add machine setup in every coordinate if you add a machine setup in the beginning if not the Gcodes will be produced depends on first machine setup.
    Mar 2011
    68
    Re: Solidcam bug
    Ok, I understand this think and also I knew it.
    Is there any posibility to disable remember last position in peration window when I use save and copy?
    Thank you!
    Mar 2011
    68
    Re: Solidcam bug
    Thank you!
    Nobody with an aswer about this?
    Thank you!
    Nov 2012
    45
    Re: Solidcam bug
    ITS NORMAL ...YOU HAVE THE LICENSE?))))))
    Nov 2012
    45
    Re: Solidcam bug
    THIS IS ALREADY RELEASED WITH HOTFIX3
    Mar 2011
    68
    Re: Solidcam bug
    Quote Originally Posted by offsets View Post
    Am scris mai jos ca am SP2HF3, si nu este rezolvata problema.
    Not resolved with SP2HF3.
    Thank you!
  1. Solidcam BUG
    By claudiu220405 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 09-22-2018, 04:47 PM
  2. Help SolidCAM and rpm
    By Peruanzon in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 07-23-2016, 12:06 PM
  3. SolidCAM g76 to G33/G92
    By vdKroon in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-14-2013, 03:30 PM
  4. should i buy solidcam?
    By gorillazp108 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 02-16-2013, 11:47 PM
  5. SolidCAM and 64 bit
    By Adam Hubert in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 10-27-2008, 06:52 PM
