586,321 active members*
3,858 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Import vise- Kurt soft jaws will not work
    Jun 2012
    266
    Good morning!
    Well I have an import twin lock double lock 6 inch vise that I would like to make some soft jaws for. Originally I thought I could order the Kurt jaws and bolt them on but they are off!
    I'm looking for a good set of dimensions. On mine from bottom to center of bolt is about 1.00 rough eyeball with my calipers. Across the centers I'm about 3.91
    Anyone else run into this?
    Sent from my SM-N910V using Tapatalk
    Jan 2007
    599
    Re: Import vise- Kurt soft jaws will not work
    Maybe you should try measuring in MM, as you said "import vise" 25 x 100 sounds like a pretty close measurement....
    Jun 2012
    266
    I will measure in mm tonight. Was just hoping someone had a blueprint etc for exact specs
  1. Replies: 0
    Last Post: 03-05-2016, 11:38 PM
  2. Master jaws for soft jaws (B2227L lathe)
    By GreatNorthGnome in forum Mini Lathe
    Last Post: 01-11-2016, 07:05 PM
  3. How does a Kurt Vice / Vise work?
    By andypugh in forum Work Fixtures / Hold-Down Solutions
    Last Post: 08-21-2010, 12:22 AM
  4. Soft jaws for the Tormach vise?
    By zephyr9900 in forum Tormach Personal CNC Mill
    Last Post: 10-29-2007, 06:13 PM
