586,510 active members*
3,506 visitors online*
IndustryArena Forum > MetalWorking Machines > Hyundai Kia > Where can I find software to an old Hit 8
    Jan 2006
    121
    Hi boys and girls,
    I´m looking for the software
    TC= DPRO Turn for 840C
    TD= DPRO Turn for 840D
    TM= DPRO Turn/Mill for 840D
    a friend of me have a Hyundai lathe Hit 8 and he told me the software he use in his system works in a normal pc.
    I buy an old Emco Concept 155 lathe and I don´t like the way to make program direct in the machinery is hard to do I need a better solution.
    Do you have or now from where I can find any copy of one of this file or all. My lathe have a C-axels and the system is Siemens Sinumerik 840D.
    I need all type of help so even a few word can bee a good start.
    Regards
    Dan
    Apr 2009
    1262
    Re: Where can I find software to an old Hit 8
    The D-PRO software requires a dongle to operate so a copy will not work. The software is readily available and reasonably priced at about 1200 for the most advanced. It includes posts for all hyundai's with similar capability like live tools (TM) and for both Fanuc and Seimens controls. It even includes engraving for that price. It runs on several versions of windows.
    Experience is what you get just after you needed it.
    Jan 2006
    121
    Fine OkumaWiz,
    If I understand some old version will works, say older from 1996 or around. I have seen one drive this on a simple pc. It was TM.
    No color, simple grafik, the most of all was as to write the numbers of all you need to do. When all whas finish you got a text file with G-code.
    A lot of people must use this even today. Okey if no one will make a copy I´m interesting if any now mor about it.
  1. Where can I find Xilog software?
    By gbrlbll in forum CNC Machining Centers
    Last Post: 04-08-2023, 01:42 PM
  2. Trying to find similar software.
    By azur in forum Uncategorised CAM Discussion
    Last Post: 10-22-2011, 04:02 AM
  3. Need to find new FANUC software
    By johnono in forum Fanuc
    Last Post: 07-22-2009, 06:30 PM
  4. 2D to 3D software. Where can I find it?
    By jaru-eri in forum Uncategorised CAM Discussion
    Last Post: 04-10-2009, 07:24 PM
  5. The most useful software that I cant find!
    By berin in forum Uncategorised CAM Discussion
    Last Post: 12-10-2004, 06:38 PM
