586,106 active members*
3,126 visitors online*
IndustryArena Forum > Tools / Tooling Technology > Calibration / Measurement > Electronic tool setters, non- conductive inserts.
Results 1 to 2 of 2
    Mar 2012
    90
    I was going to build an simple electronic tool setter for a lathe by just isolating a machined rod mounted in a the chuck and having the tool tips slow contact the rod completing a circuit and setting a X and Z location. After testing some of my tooling I found out that this won't work for everything as some of my coated inserts are non-conductive. Bummer. Anyway around this problem?
    For milling tooling I can just use a switch since the tool's location only is needed in one axis, this won't work for X on a lathe.
    May 2013
    480
    Re: Electronic tool setters, non- conductive inserts.
    spring loaded piston pressing on a razor blade breaking an optical switch should be good to .001"
    if you want to get fancy build a 10:1 mechanical advantage. should get you in the range of a tenth.
  1. Kaizen Tool box inserts
    By crash5050 in forum Aspire
    Last Post: 08-24-2014, 06:54 AM
  2. Inserts to fit K-tool octa mill OPEB 535
    By Mooser in forum Tormach Personal CNC Mill
    Last Post: 12-24-2013, 10:56 PM
  3. sugestion on choosing lathe tool inserts
    By AchillesGr in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 01-10-2012, 05:34 AM
  4. Top Tech Tool, PCD inserts
    By aaron p in forum CNC Tooling
    Last Post: 02-24-2010, 08:39 AM
  5. Probes and tool setters
    By x3UK in forum Benchtop Machines
    Last Post: 11-07-2007, 10:22 PM
