586,121 active members*
3,083 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > USB Floppy Emulator on Okuma
    Aug 2011
    419
    We use 3 digit USB Floppy emulator on all cncs. They are working fine.
    An error occours when i reinstall software.
    ERROR 334 Floppy disk recalibrate
    Why?
    I tried all jumper combinations and same error.
    "Imagination is more important than knowledge."
    Mar 2009
    6
    Re: USB Floppy Emulator on Okuma
    Quote Originally Posted by kurmay View Post
    Why?
    I have the same problem. Did you get this resolved?
    May 2021
    11
    osp-7000?osp-u100?
    Mar 2009
    6
    It's an OSP-700 with Gotek emulator https://www.ebay.com/itm/300723408804
    I can save and read program files in both Okuma and MS-DOS format.
    I get the alarm (ERROR 334 Floppy disk recalibrate) when I try to boot the battery utility.
    I successfully used the same disk image and identical emulator on another machine with the OSP-700
    Only difference I've found so far is the working machine had 1998 software and the machine I'm working on now was updated in 2006. Maybe the battery reset utility isn't used anymore?
  1. floppy to usb emulator help please
    By greggv in forum Haas Mills
    Last Post: 03-29-2016, 03:22 PM
  2. Floppy Emulator
    By ScottTheBruce in forum Toolgrinding / Toolgrinding Machines
    Last Post: 04-01-2015, 06:38 PM
  3. Floppy to usb emulator
    By MAN39ER in forum EDM Discussion General Topics
    Last Post: 09-25-2014, 10:40 PM
  4. Anyone using a USB / Floppy emulator?
    By JasonR in forum Haas Mills
    Last Post: 09-01-2014, 07:25 PM
